Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 08-07-2003, 11:54 PM   #1
Stiger
Member#: 32949
2004 STi
Silver/silver
Default Dummy switches
There are two dummy switches by the I/C water spray switch and the headlight beam leveller. Am I correct in assuming they are for foglights and the windshield wiper deicer?
Stiger is offline
Old 08-08-2003, 12:13 AM   #2
ldivinag
Member#: 13533
04 sti
black???
actually, they can BE for anything...
they are just hole covers...
ldivinag is offline
Old 08-08-2003, 12:38 AM   #3
Burke
Member#: 38939
2004 STI
Black w/ Gold Rims
Good luck getting a switch in there though. I managed to do it but I could only get a mini lighted toggle in there and I had to cover the surface with a carbon fiber sticker because I fubared the surface cutting out the square hole. The cover has a fake recess for a connector that extends back quite a ways making it real hard to cut a decent sized hole in the cover. (shakey hands + dremel tool =
Burke is offline
Old 08-08-2003, 02:17 AM   #4
Triple S
Member#: 39300
'04 STI
Silver on Silver
They are blanks sitting in the place where you can install switches. I installed a fog light switch already. You need to remove the lower part of the dash to the left and right of your steering wheel to remove the blanks and insert the Subaru switch. I used the other blank and drilled a hole for a momentary switch that I hardwired to my garage door opener, which I wrapped in old socks and stuffed behind the dash. It works great and I never need to fumble for my garage door opener. I just hit the button. If you do this, I highly recommend installing a new battery. If you do not, you might have to take off the whole dash and replace it sooner than later.
My 2 cents.
Triple S is offline
Old 08-08-2003, 10:08 AM   #5
G-shock
Member#: 36545
Default Re: Dummy switches
Originally posted by Stiger
There are two dummy switches...
I got three dummy switches!
...canadian model, no headlight leveler or HID!
G-shock is offline
Switches Switches Switches!!! snowcrzy Interior/Dressup/Audio & Security 14 02-25-2010 02:53 PM
Power Window Switch Dummy Panel? Uncle Ben Interior & Exterior Modification 0 07-21-2005 06:02 PM
Dummy switches? TeeWReX Newbies & FAQs 5 12-23-2002 12:30 PM
I'm a dummy. Darwin Normally Aspirated Powertrain 3 01-13-2001 11:18 PM
Dummy Switch Doom Technical Forum Archive 7 05-18-2000 07:21 PM
