Old 05-15-2001, 09:36 PM   #1
tabolau
Member#: 1044
2000 Impreza 2.5 RS
Post JDM 2.0 wrx turbo in 2.5 rs?
Does anyone do that? I wanted to put the JDM 2.0 wrx stock turbo, intercooler, all the piping and manifoid in my MY00 2.5 RS. Would this work? Is it hard to install? What I have to modtify to make the kit fit properly? Thanks in advance!
Henry
tabolau is offline   Reply With Quote
Old 05-15-2001, 09:58 PM   #2
kaos200
Member#: 2692
Post
you will need the engine, crossmember, and new engine management, and all the fittings, hoses, fuel system to support it...
email kevin@subafastracing.com he has a 2.0 JDM engine with turbo and air/water intercooler etc. for sale...
edit: sorry for vagueness, just email kevin he can help you out...
[This message has been edited by kaos200 (edited May 15, 2001).]
kaos200 is online now   Reply With Quote
Old 05-15-2001, 10:09 PM   #3
tabolau
Member#: 1044
2000 Impreza 2.5 RS
Post
kaos200, Thanks man, but can I just use the 2.5 L engine??
Thanks
Henry
Old 05-15-2001, 10:19 PM   #4
Digital_Boy
Member#: 730
Post
Henry,
What are you wanting to do? Do you want to use the WRX turbo setup on an EJ25 engine?
Or do you want to swap an EJ20 turbo into your car to replace the EJ25?
If the first, it'll work ok, but not great. You'll have awesome torque off the line up until about 4K RPM, then the tiny little stock turbo will start heating the air so much that any extra boost pressure will be counterproductive.
If you put a properly sized turbo on there for an EJ25, you'll need bigger up and down pipes, and an exhaust manifold. At which point you'll have been better off just getting a purpose built EJ25 turbo kit.
Digital_Boy is offline   Reply With Quote
Old 05-16-2001, 07:53 AM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
There are a couple of us in process of doing this and a couple people that have accomplished this already. Since us US folk have a hard time sourcing WRX parts, we have used '91-'94 legacy turbo parts instead. Same piping, just a slightly different turbo. If this WRX is a MY96+ then you will not be able to use the intercooler. They changed the intake manifolds and so the IC is now deeper than what the EJ25 will allow.
My site should have just about all the information you would need to get this kit up and running. Mine will be done a week into June (hopefully).
-Jon
Old 05-16-2001, 08:24 AM   #6
outback motorsports
Member#: 4084
Post
we have all the parts you need.we can also build or supply you with a bored 2.0 block ,billet fuel rails, garrett turbo,flanges etc. we're working on down pipes that fit with stock 2.0 turbos to 2.5 blocks.comp. see ya steve
outback motorsports is offline   Reply With Quote
Old 05-16-2001, 11:33 AM   #7
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
outback motorsports:
For the '98 DOHC, you can just bolt all these pieces up without a problem (or so I've been told). However, for the '99+ SOHC the differences in the head design require a 1" spacer in between the exhaust manifold and where the up-pipe bolts up to it. Since this is currently a custom peice made with whatever we can find (gaskets and exhaust flanges for now), how are you going to regulate a downpipe that will always work for these adaptations? If you have something on the back burner... I am very interested
I can call you guys if you would like me to explain further... I am the Jon that bought the lasercut downpipe flange from you guys.
-Jon
[This message has been edited by stimpy (edited May 16, 2001).]
Old 05-17-2001, 12:53 AM   #8
outback motorsports
Member#: 4084
Post
we can fab a new up-pipe,so you don't need the spacer and and i have fab-ed a new flange for the fpr so it is relocated..give us a call on our late thurs.we're there till about 1am see ya steve
Old 05-17-2001, 12:56 AM   #9
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
I will talk to you tomorrow then!
-Jon
Old 2.0 WRX vs. newer 2.5 WRX Guru Imakuni Newbies & FAQs 7 08-01-2008 10:33 PM
02 2.0 wrx vs 06 2.5 wrx mator Off-Topic 50 12-12-2007 11:00 AM
02 2.0 WRX flywheel in an 03 2.5 Legacy, will it work? meandean Transmission (AT/MT) & Driveline 3 11-15-2006 11:45 PM
can 2.5 owners use 2.0 wrx turbo kit? OutkastWRX2 Normally Aspirated Powertrain 3 07-16-2004 12:27 PM
wrx turbo in 2.5 tk__427 Normally Aspirated with bolt-on Forced Induction Powertrain 28 03-18-2002 03:59 AM
Message Board Statistics All times are GMT -4. The time now is 01:08 AM.
