Old 08-08-2003, 09:26 AM   #1
tellravi
Member#: 40409
Default Help with WRX Compression Numbers Translation
If a tech gives me WRX compression numbers on all cylinders at 65 a peice. I am assuming they are in metric. How can I translate into PSI.
Thanks
tellravi is offline   Reply With Quote
Old 08-08-2003, 09:52 AM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
from the FSM:
Compression (350 rpm and fully open throttle):
Standard;
951- 1,147kPa(9.7- 11.7kgf/cm^2, 138-166 psi)
Limit;
834 kPa (8.5 kgf/cm^2, 121 psi)
Difference between cylinders;
49 kPa (0.5 kgf/cm^2, 7 psi)
in other words, i don't know what units your tech gave you. they don't seem to line up with any of the FSM numbers.
hth
ken
Old 08-08-2003, 09:55 AM   #3
tellravi
Member#: 40409
I don't know. All I know is at 65 PSI the car would not be working.
I am thinking it may be Metric numbers. I don't know how to interpret it.
Help With Video Compression fenix Off-Topic 2 11-24-2005 10:03 AM
help with a little Spanish translation ezatnova Off-Topic 10 03-18-2005 12:59 PM
Need help with OEM part numbers for a WRX 02. AXA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-06-2005 11:57 AM
Need help with some part numbers, ASAP foolio Interior & Exterior Modification 9 12-11-2002 02:12 PM
