Old 08-08-2003, 10:49 AM   #1
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Default S-AFC to a 2003 RS...Cant locate Air Flow signal
Im doing a install on a 2003 2.5RS and we are putting in a S-AFC...
It seems 2003 has a different ECU setup and I am having trouble finding the Air Flow signal.I tried using the front O2 like some other version RS's used but Im not getting any reading on the AFC...
Anybody done this before...
jetfan8178 is offline   Reply With Quote
Old 08-08-2003, 11:56 AM   #2
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
You may want to post this in the Engine Mang/Tuning section.
joubtt is offline   Reply With Quote
Old 08-08-2003, 03:49 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Default Re: S-AFC to a 2003 RS...Cant locate Air Flow signal
no RS since the 98 or 99 has used a narrow band front 02, there fore you won't have a signal. they airflow is speed density, not MAF based like your 99. find a wiring diagram.
Jeremy
Old 08-09-2003, 09:15 AM   #4
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Default Re: Re: S-AFC to a 2003 RS...Cant locate Air Flow signal
Jeremy
I have the wiring diagram, No luck finding the wire.
Old 08-10-2003, 06:02 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
for what wire?
the map signal is what you are going to cutting and splicing the safc in line with that.
the others should just be tapped, like for rpm etc...
Jay
Old 08-11-2003, 10:57 AM   #6
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Originally posted by McDade
for what wire?
Jay
Thats what I cant find..The MAP signal(air flow)
Old 08-11-2003, 10:24 PM   #7
Jejunum
Member#: 15773
2011 Impreza WRX
OT but what is the purpose of the S-AFC ... looking for my next mod. I did some searching and saw nothing really conclusive, especcially regarding if it makes a difference in power or not.
Thanks!
(2002 RS, ganzflow cai, stromung catback, eibach prokit)
Jejunum is offline   Reply With Quote
Old 08-11-2003, 10:35 PM   #8
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
connector B136 pin 5
pink/blue
if its the same as a 2000RS
Jay
Old 08-15-2003, 11:20 PM   #9
LB2.5rs
Member#: 41107
2003 Toyota Tundra
1987 cbr600 teh Hurricane
You dont know which wire the rear o2 sensor is do you?? Ive been looking forever to find a wiring diagram, but i cant. They say its white, but there are 2 white wires. I onno. Also does anyone know where/what color the ignition wire is?? Thanks.
Luke
LB2.5rs is offline   Reply With Quote
(nj) Apexi S-afc Air-flow Meter RUBEN Private 'For Sale' Classifieds 1 12-14-2004 05:55 PM
Apexi S-AFC II Super Air Flow Converter berzerkled Private 'For Sale' Classifieds 1 02-14-2004 02:02 PM
Apexi S-AFC - Super Air Flow Converter ilmaestro Private 'For Sale' Classifieds 3 02-04-2004 05:55 PM
Air Flow reading 00.00% on S-AFC???? HpiRally Normally Aspirated Powertrain 9 03-13-2002 05:38 PM
Message Board Statistics All times are GMT -4. The time now is 01:03 AM.
