Old 08-08-2003, 11:04 AM   #1
Jay04WRX
Member#: 34075
2009 CTS-V
Default Engine managment for an 04 WRX (please help)
I currently have a Utec which I can at this point do without. I had it professionally tuned and it is still knocking. I know that it is a user tunable ECU and to get rid of knock I need to tune it out.
I basically bought the wrong product. I want a set it and forget it type of engine managment for my 04 but I do not know what is out there. I have a TXS stage 2 with up-pipe & Utec.
Does anyone know of any engine managment product that is set it and forget it? I basically dont want to knock and I was told that my Utec is aggresivly tuned so I will get knock due to boost, weather, gas etc. I also know that you guys would like to see a log but I have not gotten around to learning how to tune the Utec myself, basically i do not have the time with work and all.
I am in the process of getting gauges also.
Basically I like the Utec but see no point in having something I will not use on a reg basis. I want to add mods and I know a reflash system I will have to re-flash everytime I add mods. Does anyone know if the Unichip will work in my 04 WRX?
Like I said I have a stage 2 with up-pipe and I am thinking about a diff engine managment tool and or a MBC plus a bigger top mount for my car. As for engine managment I was told about Cobb and ECUtek for the 04....
Can someone please give me some guidance and imput I would appreciate it.
thanks
Jay
Jay04WRX is offline   Reply With Quote
Old 08-08-2003, 01:31 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
You should consider conforming your car to one of the configurations described at http://www.cobbtuning.com/wrx/accessecu.html. This has two distinct advantages for you:
  • You won't have to retune your car for changes in weather or gasoline quality.
  • You won't have to make decisions on which new component to buy for your next upgrade. Instead, you choose a new configuration from that page, collect the specified new pieces and install them as a group while your ECU is reflashed to support them.
The result is a tune designed exactly for your equipment at a resonalble cost and without requiring that you become an expert on anything except driving.
Jon [in CT] is offline   Reply With Quote
Old 08-08-2003, 01:35 PM   #3
capaWRX
Member#: 37768
MY12 wrx ltd
98 2.0rs (sold!)
check out cobb forums for all the info you'll ever need..[edit - on the aECU]
capaWRX is offline   Reply With Quote
Old 08-08-2003, 02:09 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Vishnu Tuning offers the "same" product.....my ECU is going to Cobb on monday.....
Old 08-08-2003, 02:14 PM   #5
Jay04WRX
Member#: 34075
2009 CTS-V
the only worry or problem I have about Cobb and Vishnu ECU's is that if you get knock you are not told or warned in any way. The CEL does not flash so at any point in driving your car you can be doing major damage to the engine from what I have been told.
Old 08-08-2003, 02:43 PM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
The CEL will flash to indicate severe misfire. A stock engine with the stock ECU won't flash for knock, either. Nobody gives this a second thought. A reflashed ECU from a knowledgeable tuner that's been tested under varying conditions with numerous vehicles equipped with the same bolt-on configuration should not give you pause for concern either. If it does, you might as well just hang it up right now since there's no safer alternative.
Old 08-08-2003, 02:50 PM   #7
Jay04WRX
Member#: 34075
2009 CTS-V
Originally posted by Jon [in CT]
The CEL will flash to indicate severe misfire. A stock engine with the stock ECU won't flash for knock, either. Nobody gives this a second thought. A reflashed ECU from a knowledgeable tuner that's been tested under varying conditions with numerous instances of the same bolt-on configuration should not give you pause for concern either. If it does, you might as well just hang it up right now since there's no safer alternative.
I have a Utec in my car which was tuned professionally but still knocks. I want an engine management tool that will not have to be messed with every other day. I will have my car tuned and dyno'd again next week sometime since it is owed to me. If the knock continues I am going to look into different options but if everything looks good and I do not knock I will keep my Utec.
p.s. where do you live in CT?
Old 08-08-2003, 03:06 PM   #8
Jon [in CT]
Member#: 2992
02 WRX Sedan
The fact that a person that makes money from tuning (aka "professional tuner") obviously doesn't assure success. The fact that a piggyback ECU is easily modified obviously doesn't assure success.
Just picked up an 04 wrx (need help) 04bluedubRex North West Impreza Club Forum -- NWIC 10 07-08-2008 02:38 AM
who can do an engine management for my 04 wrx,i will pay you.! sexycat Mid West Subaru Owners Club Forum -- MWSOC 11 03-16-2008 03:39 AM
Link 44S: User Tunable Engine Management for 02/03 WRX RicerJim Private 'For Sale' Classifieds 1 05-28-2006 04:06 PM
Link 44s User Tunable Engine Management for 02/03 WRX RicerJim Private 'For Sale' Classifieds 60 05-26-2006 05:47 PM
engine managment for an EJ20G 93 wrx 99WRXEJ20 Private 'Wanted' Classifieds 1 01-28-2004 12:51 PM
