Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 05-24-2001, 12:53 PM   #1
delipinoy
Member#: 6892
2002 WRX Blue
14.230@95.96 mph auto
Cool Blowoff Valve
What is the best blowoff valve out there in the market for my WRX? I just got my car on saturday and I am tempted to upgrade everything. I am also looking for a body kit for it so if you can help me in finding someone that makes it, I thank you.
My upcoming upgrades that I want to do is:
exhaust
blowoff valve
18" Racing Hart Z5000's or 5Zigen 5ZR's
suspension kit
body kit
delipinoy is offline   Reply With Quote
Old 05-24-2001, 03:09 PM   #2
Gethin
Member#: 2998
OpenECU+UTEC
Post
Your car already has a blow off value
aka dump valve
it's a recirculating type.
If you want more sounds then upgrade to a induction kit so you can hear the valve dumping air back in.
If you want big whoosh whoosh sound effects go for a dump-to-atmosphere, make sure it's the sequential type and that you get your car on a Rolling Road to make sure it's running OK after fitting it.
Personally i'd go for a Bailey-type piston recirculating type. Safest bet
Gethin.
Gethin is offline   Reply With Quote
Old 05-24-2001, 03:34 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
Post
2002 WRXex are equipped with an exhaust wastegate valve to regulate boost pressure. Is that the same as a "dump" valve?
Jon [in CT] is offline   Reply With Quote
Old 05-24-2001, 03:56 PM   #4
MysteryMachine
Visiting NASIOC Timeout
Member#: 6500
Lightbulb
Hey fellow flip with a WRX. I work over in Monrovia off of Huntington Drive. I just ordered a TurboXs Blow-off valve and will be getting it this Friday. Stop by sometime next week if you want to see how it sounds. As for the rims you want, make sure that they come in the correct offset because only the CP-035's are currently available (i believe). Check out the following link for body-kits and wheels. Takakaira
PM me if you want to check out the B-off valve
[This message has been edited by MysteryMachine (edited May 24, 2001).]
MysteryMachine is offline   Reply With Quote
More Hot Topics on NASIOC...
Old 05-24-2001, 03:59 PM   #5
SilverSubie
Member#: 4375
Post
noooo...a dump valve is the same thing as a bypass valve. it dumps or bypass the pressurized air back into the intake when you shift or let off the gas at a certain preset pressure. TurboXS makes a racing bypass valve can hold up to 35psi and they already have an adapter that fits the 'rx.
-grant
SilverSubie is offline   Reply With Quote
Old 05-24-2001, 04:18 PM   #6
flipguy80
Member#: 5987
Platinum Silver Metallic
Post
The TurboXS BPV doesnt fit well under the hood of the WRX. I got an email about it. I personally just got in a Forge valve ( Stratmosphere ) so I'm gonna check it out as soon as i get out of work.
-David
PS: wassap flipz!
[This message has been edited by flipguy80 (edited May 24, 2001).]
flipguy80 is offline   Reply With Quote
Old 05-24-2001, 05:04 PM   #7
Blugin
Member#: 5270
2008 EvoX MR
Red
Post
You can check out mine here: http://www.i-club.com/ubb-files/Foru...ML/003696.html
it's made for the wrx and it is L O U D. I hear it is quieter when switched to hybred mode, but this one is set to full vent.
Company- GFB
Blugin is offline   Reply With Quote
Old 05-24-2001, 08:58 PM   #8
Frank
Member#: 3791
Post
check out the what the S4 guys think of those forge valves on Audi World. Nothing but a crappy knock-off.
Frank is offline   Reply With Quote
Old 05-24-2001, 10:01 PM   #9
Wreqs
Member#: 6642
02 WRX AT sedan
Post
Jon, in more simple terms, when accelerating, the wastegate closes, directing exhaust gas through a centrifugal turbine which is connected to a centrifugal compressor through a shaft. The compressor takes ambient air and pressurizes it, forcing it into the intake manifold, on it's way into the cylinders. When you let off the gas or shift during this cycle, that pressure from the turbo's compressor needs to be vented to prevent that pressure from being forced backwards through the compessor, slowing it down and compomising the seal. performance and turbo protection.
Wreqs is offline   Reply With Quote
Old 05-24-2001, 10:07 PM   #10
Wreqs
Member#: 6642
02 WRX AT sedan
Post
I'd like to know how a bov is set and how you chose the setting
Old 05-24-2001, 10:48 PM   #11
Tuning Factory Inc.
Vendor
Member#: 3600
Post
I love my blitz personally.
<IMG SRC="http://godspeed.hack.net/images/WRXBlitzBOV2.jpg" border=0>
Tuning Factory Inc. is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 04:03 PM.
