Old 05-17-2001, 07:12 AM   #1
Keith
Member#: 191
2012 J train
Brown
Post Whats the deal with the power surge when you let off the gas?
I know this was talked about before, but I'm lookin for some new info.
Since I have my egt now, I notice that when that power surge happens, the egts spike up about 50 degrees! needless to say, thats not good
So whats the deal? would a better (faster reacting) bov fix that?
Thanks
Keith
Keith is offline   Reply With Quote
Old 05-17-2001, 09:35 AM   #2
Keith
Member#: 191
2012 J train
Brown
Post
Dont make me find you guys in your sleep
Keith
Old 05-17-2001, 09:44 AM   #3
WRacerX
Member#: 4365
2004 Forester XT
Post
Here's my undeducated guess..
The BOV just releases the pressure behind the throttle plate, right? I would guess the surge is caused when the throttle plate snaps shut and the leftover pressure in the intake manifold (other side of the throttle plate) is consumed by the engine as a lean-boosted mixture. So, I don't know how a faster BOV would solve the surge problem. Seems more like an ECU tuning issue.
WRacerX
WRacerX is offline   Reply With Quote
Old 05-17-2001, 09:48 AM   #4
blkwag
Member#: 4838
2002 WRX Wagon
Black in Recovery...
Post
I've noticed on my car that the power surge has increased when I switched over to an aftermarket BOV and venting to full atmosphere. I don't know if this has any relevence or not.
blkwag is offline   Reply With Quote
Old 05-17-2001, 10:11 AM   #5
UCI_Scott
Member#: 5088
Post
This is not the final answer, but I believe that the RPM increase at clutch-in / lift-throttle is programmed into the ECU to keep emissions low. In general, lift-throttle generates a run rich condition. By taking control over the lift-throttle, the ECU closes the throttle body s l o w l y allowing the fuel/air mixture to remain lean. The RPMs do not rise because the throttle is electronically increased; they rise because the load on the engine decreases while the throttle stays temporarily constant/closes slowly. It may not even be the ECU; it's possible that there is some simple mechanical damper preventing a snap-close of the throttle body.
As for the spike in EGT, I believe it is of little consequence off-power. It's just the system normalizing for a different operating mode. If it spikes when you are on-power it is more of a worry; a glitch in the fuel map or boost map.
--scott
UCI_Scott is offline   Reply With Quote
AC compressor Knocks when I let off the gas Joebrauk Newbies & FAQs 1 05-26-2010 06:52 PM
whirring noise when I let off the gas alacrity024 Transmission (AT/MT) & Driveline 10 08-14-2007 07:10 PM
Why would a car shut off when you lift off the gas? linux>windows Off-Topic 28 03-08-2006 08:38 PM
Noise when I let off the gas BlackRex05 Service & Maintenance 10 10-02-2004 11:21 AM
Weird winding noise when I let off the gas... Siper2 General Forum Archive 12 12-09-2000 09:15 AM
