Old 08-08-2003, 10:17 PM   #1
wyowrx
Member#: 34157
00 Toyota MR-S
Default Utec tuning tip
Anyways at the track and got a knock event on my log while letting off throttle in 3rd gear at readline. TPS went to 0 and boost was still present and the ECU tried to run 38 deg timing!!!JustDSM figured it out and suggested the following:
Copy 5000 and down timing to 0% column. This way if you let off the throttle at high rpms with resident high map, you wont get det.
wyowrx is offline   Reply With Quote
Old 08-09-2003, 05:07 AM   #2
JustDSM
Member#: 17502
So I take it, the knock issue cleared itself up?
I think you should also note that the ECU your using is reflashed by Vishnu (which runs excessive timing up top). I don't recall seeing advance numbers that high on stock ECU'd cars. I'll have to check some logs to verify however.
JustDSM is offline   Reply With Quote
Old 08-09-2003, 07:01 PM   #3
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
wyowrx,
Nathan and I usually find that adding some fuel there is a "smoother" running option.
Thanks,
Phil
TurboXS
motoxphil is offline   Reply With Quote
Old 08-09-2003, 09:52 PM   #4
JustDSM
Member#: 17502
Originally posted by motoxphil
wyowrx,
Thanks,
Phil
TurboXS
Phil/Nathan,
I typically do as you suggest to eliminate knock in scenaro's like the above, however in Jack's particular case his ECU was reflashed by Vishnu. I've not paid very close attention to the ammount of advance that the OEM ECU spits out at these rpm/load points. But I've seen a few of Jack's logs where his reflash thew out 38+ degrees on the top end. I know that his setup is running grossly rich pretty much throughout the map (minus the 0% column) and believe that the knock he encountered was induced from overly advanced ignition timing.
I dont believe people with OEM ECU's will need to map timing into the 0% column's for the reasons you suggested, however Jack's case is a little "unique".
Old 08-10-2003, 12:34 PM   #5
motoxphil
Member#: 5094
JustDSM,
Try it, as adding + Maf will move the calculated load in the factory ecu, thus changing the ignition timing also (more MAF usually means a higher load calculation which can result in less ignition advance).
But, as you stated this is a reflashed ecu and I don't know what was altered. You can change the timing at the 0% load column but it just takes time to get it smooth and consistent.
Good luck.
Phil
TurboXS
PDX Tuning Coming to Houston - Open Source, Ecutek, AccessPort, UTEC Tuning Geoff Texas Impreza Club Forum -- TXIC 53 10-14-2009 11:27 PM
UTEC tunning tips needed kool168 Engine Management & Tuning 3 01-06-2005 01:40 PM
Turbo XS UTEC - Pointers, Tips, Do's & Don'ts Konvict Alaskan Impreza Club Forum -- AKIC 12 08-05-2004 05:34 PM
Utec Tune...Anywhere to get tuned? urabusXRW Tri-State Area Forum 1 11-23-2003 08:17 AM
Utec tuning tips AZScoobie Engine Management & Tuning 48 10-18-2003 02:24 PM
