Old 08-09-2003, 10:54 AM   #1
rupertberr
Member#: 12183
13 WRX,09FXT,924s
2008NASIOC Pick6 F1 Champ
Question Adjustable camber plates legal for PGT?
I am having a hard time getting the camber right on my new struts. I was going to order adjustable camber plates. After reading the rules I am not completely convinced they are legal:
page 99, "...if it is necessary to replace the entire MacPherson strut, the replacement parts must be mechanically equivalent to the original ones and have the same mounting points."
The mounting points are the same but are they mechanically equivalent?
rupertberr is offline   Reply With Quote
Old 08-09-2003, 03:19 PM   #2
KeithRS
Member#: 3436
1987 Rockhopper
Yellow
I don't know that answer, but I have a set sitting on a shelf that I will put in as soon as I get around to putting in some struts...
Let me know if you get a good answer somewhere. FWIW, I wouldn't mind if anybody was using them in our rallycrosses, regardless of the word from the SCCA.
KeithRS is offline   Reply With Quote
Old 08-09-2003, 03:43 PM   #3
outback2.5HO
Member#: 15135
95 GF WRX
Unhappy
Don't think those are legal for PGT, they are not the mechanical equivalent of stock since they are adjustable and stock ones aren't.
To be completely sure you should email Doug Robinson of the SCCA and he'll give you the absolute answer.
outback2.5HO is offline   Reply With Quote
Old 08-12-2003, 04:54 PM   #4
rupertberr
Member#: 12183
13 WRX,09FXT,924s
The short answer is: No.
Doug's suggestion was that I could modify the strut. We will see how easy that is.
Keith, I appreciate your opinion. Just want to stay squeaky clean in PGT. May have to move to Open next year.
Old 08-12-2003, 09:52 PM   #5
KeithRS
Member#: 3436
1987 Rockhopper
Yellow
Well, humph. I am still putting them in just to have some decent camber up front. I probably won't get around to it until the end of the year, either.
Old 08-13-2003, 07:48 AM   #6
Kha0S
Member#: 8808
2011 WRX
DGM 5D
I don't think the book is closed on this one. The term "mechanically equivalent" in terms of suspension components for rally is pretty open... that is, you can drastically change your damper/spring combination, go to remote reservoirs, invert your struts, etc., all without breaking the rules. Adjustable vs. non-adjustable means nothing with these components... virtually everyone in all classes has adjustable suspension components.
Similarly, I'd be inclined to consider the strut top as part of the strut, and therefore, any camber plate that replaces the top strut mount and uses the same bolt pattern onto the body of the car as legal.
Regardless, even if it used a different pattern entirely, as long as it bolts to the same part of the car, you won't get a protest from me.
/Andrew
Kha0S is offline   Reply With Quote
DMS Front Race Adjustable Camber Plates-GC/GD/04 STI-Exceptional Camber Plate!!! Saabaruba Suspension/Brakes/Handling 12 01-02-2010 05:51 PM
WTB: Adjustable camber plates for WRX Subdued North West Impreza Club Forum -- NWIC 3 02-19-2003 11:36 AM
Adjustable Camber plates, 02 WRX ? Branwell Brakes, Steering & Suspension 5 11-07-2001 01:55 PM
