Old 05-18-2001, 08:17 AM   #1
MJSpiers
Member#: 4915
2002 WRX Sedan
Question Blitz DSBC settings
Hi,
Has anyone installed a Blitz DSBC boost controller in their WRX yet?
I just installed mine yesterday, and am looking for some advice on the settings...
I currently have it set:
Boost: 20%
Warning/Limiter: 1.05Kg/cm2 (dial-back -7%)
Gain: 5
Scramble: 0/0 (off)
Could anyone explain what the scramble setting does? From what I gather, it will promote a boost spike of a certain ratio for a certain number of seconds. Maybe I'm thick, but I thought this was bad? Anyway, I turned it off!
Any help, much appreciated!
Edit:
Just changed things a bit as the above settings seemed to be too conservative - i.e. only hitting .5Kg/cm2.
New settings:
Boost: 45%
Gain: 5
Scramble: 0/0 (off)
With these settings, I'm hitting a peak of .78Kg/cm2. Does anyone know what the stock Kg/cm2 setting should be?
[This message has been edited by MJSpiers (edited May 18, 2001).]
MJSpiers is offline   Reply With Quote
Old 05-18-2001, 09:05 AM   #2
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
Post
I can't think of my settings right now, I'll check when I get home and post them. I have a few mods though so of course settings will be different with your mods.
Ken
DeliciouSpeed is offline   Reply With Quote
Old 05-18-2001, 12:37 PM   #3
JaMa
Member#: 5206
Post
I have the unit set:
52% boost
0 gain
1.07 warn
Seems to work fine. The solenoid clicking is somewhat annoying though.
JaMa
JaMa is offline   Reply With Quote
Old 05-18-2001, 12:46 PM   #4
p7r4e7y
Member#: 4261
2000 2.5 RSTI
www.ModernImage.net
Post
i am running stock w/o boost controller and my peak is about 1.05kg/cm2
which is 14.93 psi but thats probably a spike
im i more consistantly get up to .98kg/cm2
13.93 psi
p7r4e7y is offline   Reply With Quote
Old 05-18-2001, 12:52 PM   #5
JaMa
Member#: 5206
Question
I must say I am pretty confused by the DSBC unit. The readout is in kg/cm2, which is how many PSI or Bar? Is 1.00 kg/cm2 1 bar or 14.7 PSI or is the Blitz outputting differently? What good is the boost gauge on the controller if it does not give a real boost reading which we can read?
Also, where did you guys mount your units? I put mine in the little blank silver plate over the radio to the left of the cupholder. It is a really cool place to have it, though we did have to cut the plastic to mount it. Still, it is right in front of me and very readable/accessable.
What about the clicking? Do you other dsbc guys have the clicking under the hood as well? Does it get any better with time?
JaMa
Old 05-18-2001, 12:59 PM   #6
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Post
JaMa:
Check out my site, under the DIY Mods area. The first link takes you to a calculator page...
calculate to your hearts content.
Fast Facts...
The stock wastegate is .6 kg/cm2
~13.5 is .95 kg/cm2
1.10 kg/cm2 is around the 15/15.5 area..
If you scramble to about .5 above that your pretty safe. With out some sort of octane booster you are playing with fire above 1.1 kg/cm2 guys... You could run fine... or KNOCK HARD. Your call!
Jorge (RiftsWRX) www.ProjectWRX.com
P.S. these are the settings I run on my EVC IV..
RiftsWRX is offline   Reply With Quote
Old 05-19-2001, 01:08 AM   #7
pbnj9786
Member#: 4473
MY10 STi
Plasma Blue Pearl
Post
1.0 kgf/cm^2 = 14.22 psi.
you are welcome.
pj
pbnj9786 is offline   Reply With Quote
install: blitz dsbc Evo-Killa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-13-2002 01:47 AM
Blitz DSBC Install? Alxaguiar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-16-2001 12:21 AM
Blitz DSBC or SBC-iD? jamz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-05-2001 11:02 PM
Blitz DSBC Setting? JohnWad Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-21-2001 06:48 PM
Blitz DSBC TARMAC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 04-25-2001 08:08 AM
