Old 08-09-2003, 01:57 PM   #1
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
Default slow/low boost with downpipe install
I just got done installing a bosal twin dump downpipe and a 2.5'' catback exhaust.
I have a AccessECU stage 1 Reflash and an uppipe.
I am experience low and very very slow rising boost. I max boost around 11-10psi. When i first test drove the car the boost acted normal, but once i got on it, it seems like the computer limited my boost.
Could this be because of the Stage 1 reflash, causing the boost limiting?
I want to try and put my mbc on and see if i get normal boost capibilities with that, then i should know if its the ecu.
Please respond.
03WRX83 is offline   Reply With Quote
Old 08-09-2003, 05:56 PM   #2
esteve
Member#: 28716
2006 STI
I would send your ecu back to Cobb ASAP for the stage 2 reflash and give them a call about this.
I read about some problems with certain Bosal DPs where the splitter went into the turbo housing too far and messed with the wastegate's operation. I guess you could check it by manually opening/closing it and feeling for anything not right.
I would think it's your mismatched combo causing this problem but a lot of people have put TBEs on stock ecu's with none of the boost problems you have. Maybe with the stage 1 it's different.
esteve is offline   Reply With Quote
Old 08-09-2003, 05:59 PM   #3
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
i can achieve boost with the operation of the mbc that i put on.. but if i hit full boost and keep it there it seems the computer then limits it..
but just driving easy 0-7psi and such boost works great.
so i dont think its the dp.
Old 08-09-2003, 07:51 PM   #4
Barry
Member#: 11554
2016 STI
Ice Silver Metallic
left you a link in your other post........
Barry is offline   Reply With Quote
Old 08-10-2003, 12:14 PM   #5
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
barry how come i can get boost with the mbc though?
Low boost after turbo install.... abosworth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-11-2008 08:06 PM
low boost after fmic install Sc00byDrew Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-28-2007 10:03 PM
Low/slow rising boost after DP install 03WRX83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-11-2003 05:36 PM
low boost after uppipe install wrxtcy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-05-2002 01:32 PM
Low boost with Legacy turbo? Diz Technical Forum Archive 7 09-07-2000 12:50 AM
