Old 08-09-2003, 02:56 PM   #1
JDMpreza
Member#: 36312
2003 2.5 RS
Midnight Black Pearl
Default Need some help on first mods
ok basically i want my car running like mid-high 14s ASAP, so i need some help.
what mods would i need to accomplish this?
i have a 03 RS and i already have a magnaflow muffler with custom pipping. i'm looking into the cobb cai, what else should i get?
i'd really like low 14s, is this possible while staying na?
JDMpreza is offline   Reply With Quote
Old 08-09-2003, 03:07 PM   #2
Surb00
Member#: 27132
1999 2.5 RS-T
Rally Blue
You are going to want to look into cams and maybe some headwork to get down to 14's. Intake and a full header-back exhaust could prob. get you to the low 15s.
Surb00 is offline   Reply With Quote
Old 08-09-2003, 03:27 PM   #3
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Good start. Here's what else you need to run low 14s NA:
  • Cobb street cams (or 'spicy' cams if you like)
  • Equal-length headers like MRT + midpipe
  • Lightweight flywheel
  • Stronger clutch
  • A budget for transmission repairs/replacements or a 6MT.
None of that will pass a smog check except the cat-back. The cams will make you even fail the sniffer test, so be aware of that. Otherwise, that will get you there. You could also strip as much weight as possible out of the car if you're really hardcore, but to be honest swapping cams is easier. If you do cams, heads, serious weight reduction, and some other small things like wires, plugs, ECU tuning, etc., you *might* even get to the 13s.
Yup. Cobb intake + full MRT header-back = 15.1 with a good launch.
BAN SUVS is offline   Reply With Quote
Old 08-10-2003, 02:04 AM   #4
JDMpreza
Member#: 36312
2003 2.5 RS
i've heard of low 15s with just intake. but anyways, i'm thinkin COBB CAI next, then headers, then cams. what about pullies? also what would be the best type of header and cams?
Old 08-10-2003, 05:20 AM   #5
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
You don't cut a full second off your ET with one mod unless it's nitrous. Lightweight stock diameter pullies work ok, but light flywheels are more effective. Since you'll need a clutch eventually, just have the new flywheel installed at the same time. As for which exhaust and cams, see above post.
05 STi, need some help planning out mods. 0BLUEWRX3 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 03-24-2008 06:18 AM
Need some help, tuning suggestions/mods shvrdavid Normally Aspirated with bolt-on Forced Induction Powertrain 1 02-02-2006 08:10 PM
Ok..need some advice on 1st mod elk29n Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-27-2003 06:58 AM
Ok, need some help on mod decisions... ScreaminFast Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-29-2003 12:19 PM
New WRX and need some help on some mods 02WRXguy Texas Impreza Club Forum -- TXIC 19 07-16-2002 11:49 PM
