#1 |
Member#: 35703
Vehicle:2004 WRX STi Blue/British Black 18's |
Mine was really hard to pull. I thought I'd break it so many times opening the trunk. So what I did to fix it was go to the trunk and pull the internal safety release lever (the one inside the trunk) about 6 times. For some reason it totally fixed the cabin release lever completely. It must have loosened up the cable or something. Whatever I did, it worked great; It's super easy to open now! No guarantees it will work for you but it's worth a try.
#2 |
Member#: 41507
Vehicle:2004 sti blue |
Mine is too,Yes but now you have to get in the trunk and close the lid shut and make sure the safety release works.If we do not here from you will assume you broke it!!
#3 |
Member#: 35703
Actually, I did get in the trunk and shut it to release it! I had someone with me that I trusted! Anyway, only get in and try it if the first method doesn't work.
#4 |
Member#: 40890
Vehicle:04 WRX Sedan Black |
Mine's still a little sticky but I find that if I slam the trunk shut pretty hard it is easier to open the next time. That's about as easy as it gets, right?
#5 |
Member#: 41507
yes mine is hard to pull open,when I first got the car I thought it was broken,then I tried the key and that was not working ether.So a couple days later I just pulled up real hard on the inside lever and it poped up,then I looked inside and flicked the switch from cancel so I could use the key.But you are write I thought I was going break it.When I get mine back from dealer I will try what you did Matt Hope the joke did not bother you!!
#6 |
Member#: 35703
No, mine is not even a bit sticky anymore. Get in the trunk and try the internal release a couple of times.
#7 |
Member#: 18713
Vehicle:06 CRV 04 STi |
I'm going to try this.
#8 |
Member#: 41793
Vehicle:2004 Impreza STI Pearl Black |
Just tried that, it worked great, hopefully it will stay that way. If it only temporarily fixes it I’ll post back.
#9 | |
Member#: 8023
Vehicle:2004 2.5 RS |
#10 |
Member#: 393
Vehicle:2011 Toyota Sienna & 99 Ducati 900ss |
You guys do know that this subject has been addressed and there is a quick and easy fix for it. DonA posted it about a month ago.
#11 |
Member#: 18713
I moved the trunk latch, and that improved the release.
but...it would be much easier to just pull the handle a couple of times, if that did the same thing. |
| Thread Tools | |
| Display Modes | |
| how to fix trunk release lever? | got0azn0rice | North West Impreza Club Forum -- NWIC | 4 | 09-09-2008 08:45 PM |
| Trunk release lever not working... | Toadsworth | Newbies & FAQs | 5 | 07-18-2008 09:41 PM |
| broken trunk release lever | ddfearhe | Newbies & FAQs | 7 | 04-21-2008 01:37 AM |
| WTB: 04 STi Passenger Side Windows & Trunk Release Lever | V8killah91 | Private 'Wanted' Classifieds | 0 | 07-23-2007 06:04 PM |
| WTB fuel/trunk release levers | willyb | Private 'Wanted' Classifieds | 0 | 06-09-2005 09:32 PM |
