#1 |
Member#: 41507
Vehicle:2004 sti blue |
I was driving my sti(showing my dad new sti) put in manual mode(all the way to bottom setting) drove in first gear a little bit,stopped car put on hand brake.Got out of car,got back in car let brake off,put back in automatic mode but would not go.Restarted car it went into automode untill I get into 3 gear and goes write back to the mnual setting and can not switch it.The manual says this is a dccd falure take to subaru dealer for inspection.I am really upset,is all right to drive it like this,I drove it home thats it about 2 miles.It is suppose to reset when the hand break is used and will go back to the original manual setting.It only has 400 miles on it.Any help or advice thanks Matt the dealer is not open till monday and I need a car for work
#2 |
Member#: 456
NWIC
Vehicle:2008 Forester XT Steel Gray Metallic |
My guesstimate is that the DCCD fails open --- you should be ok to drive it. Any other lights (like rear diff temp?)
#3 |
Member#: 41507
Hi Glen,nice to meet you and thank you for the fast reply.I enjoy the website and your answers to questions.No the diff temp lite is not on.The only light is the failure system lite for the dvvd.When I start the car and drive all is ok till about 3rd gear ,then it goes out of automatic and to the last setting on the bottom(closest to the armrest) and flashes.After it does this it stays stuck there can not go to automatic or manuel.
Is this a seruos problem or just a sensor or reset type of thing? I never drove around in the manual mode or got on it at all,really babying it,except for jumping in traffic and doing 75 mph to mantain the flow of traffic going into New Jersy to work fromPA.It is a hour and half each way to work and I am affraid to drive it that far Matt!! |
#4 | |
Member#: 33246
Vehicle:1993 Legacy L+ AWD Phoenician blue met./blue |
I'd go straight to the dealership Monday and drop it off for a diag. Your warranty will cover it fully, don't worry. - Janq |
#5 |
Member#: 16791
Vehicle:2004 WRX STi WRBlue |
You could try disconnecting the battery to reset the computer and try it again. It may just be an electronic glitch...
#6 |
Member#: 456
NWIC
Yeah, get the dealer to look at it. Possible problems: faulty G sensor, faulty solenoids in tranny, not getting good ABS tone signals from ABS system. (though I assume ABS light isn't on).
You weren't driving it hard at low speed on pavement with the diff locked were you? Glenn |
#7 |
Member#: 41507
Thanks again everybody for the help,
No the lock was never on ever and it was never driven with lock on.It was driven once at the dealership with the salesman with it in manual all the way open (least) at bottom of green display.Then I did it once with my dad on a dirt road drove slow in first gear thats it. I was thinking about disconnecting the battery too,but figure I might clear the fault codes for the mechanic to see also might look like I am trying to hide something!! Thank you Matt kb3drf sti |
#8 |
Member#: 456
NWIC
Let us know what they replace.
#9 |
Member#: 41507
Yes I sure will Glenn so you can help others.Today(sunday morning) I went out to the sti and figured maybe it has stopped now that it has sat for a day(wishfull thinking).Anyway I started up and all was fine drove about 20 miles stopped for gas and stopped and started a couple times stayed in automode no flash,then at about 35 mile mark it did it again when out of automode to bottom of manual mode and flashes.Oh well thought it was just a fluke and would pass guess not.I will call dealer tomorrow.I bought the car in Up state New York not from local dealer.Matt(Keep you posted on what the dealer finds) thanks !!
#10 | |
Member#: 33246
Was it you and your dad that picked up your car from Van Bortel about a month ago? When I was there to pick-up my car one of the porters mentioned someone had come recnelty to pick-up and STI and that they were going to drive it home to "Dallas". I just noticed your location as "Dallas, PA". Anyway, your Subaru warranty is good everywher ein the US at any dealer regardless of who you bought it from. Don't worry you'll be taken care of wherever you go. Best of luck! - Janq |
#11 |
Member#: 41507
Hi jang,No that was not me I got mine at a different dealer( royal family).Update took to dealer today at 9 they srarted at 3, at 3.15 they call and say it is done I ask what was wrong she says nothing that lite is suppose to be on,I said I do not think so,in the manual it says that is dccd failure when it flashes,she says oh it flashes ok let me call you back,call back at 4.30 well we will have to keep it here cause were waiting for subaru to call backAGAIN to tell us what to do.We never worked on an sti.This is new to us.So thats were we stand,single and need my wheels for work,I guess I will pull one of my classics out that was never in rain since 1968 day one ,and kill it in the rain!!Not happy Matt I hope I fall in love with this car it is really stressing me out from buying to this and everybody says I was stupid for paying
all that money for wrx with no radio even you know the rest of how that goes.It looks infintile with the wing and scoop. |
| Thread Tools | |
| Display Modes | |
| DCCD failure/ ABS light | KevinK | Newbies & FAQs | 2 | 12-29-2009 06:13 PM |
| DCCD Failure on 05 sti | z_wrecker | Factory 2.5L Turbo Powertrain | 83 | 11-20-2004 03:11 PM |
| DCCD Failure Fixed/Important Info Shared | kb3drfsti | STi Forum Archive | 9 | 09-05-2003 07:20 AM |
| dccd failure update Matt seriuos!! | kb3drfsti | STi Forum Archive | 13 | 08-19-2003 10:57 PM |
| kb3drfsti - what is the result of your dccd failure? | Conecrusher | STi Forum Archive | 5 | 08-16-2003 06:14 AM |
