Welcome to the North American Subaru Impreza Owners Club Thursday February 26, 2015
Old 08-09-2003, 11:44 PM   #1
quickscooby
Member#: 39415
STI 444/452@26psi
479/492 @ 30psi GT30R .82
Default A/F ratio in Delta Dash
When i floor the gas in my car delta dash always reads 11.24 at WOT. When i let off it gets real rich. My question is will it always read 11.24 at WOT? i just want to know if i lean it out if it will start to show that and go to like 11.5 or something. It seems to be true because i saw a 12.3 i believe once i sprayed the ntercooler kit.
quickscooby is offline   Reply With Quote
Old 08-10-2003, 12:37 AM   #2
Delicious Tuning
Member#: 1990
The lowest the DeltaDash will read is 11.24 this is because this is the lowest level the front Wideband O2 sensor reads through the stock ECU accurately, or pretty close to it.
If you really want to know A/F ratios you will want to get an aftermarket Wideband O2 Sensor kit.
Bill (EcuTeK Tuner) @ I-Speed USA
Delicious Tuning is offline   Reply With Quote
Old 08-10-2003, 02:55 AM   #3
quickscooby
Member#: 39415
STI 444/452@26psi
Yeah i know that. What i mean is will it read above 11.24 accurately like if i was at 12.2 or something?
Old 08-10-2003, 03:27 AM   #4
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Default Re: A/F ratio in Delta Dash
Yes when Delta Dash interprets the signal as being higer than 11.24:1 AFR it will reflect that number. I can not speak to the accuracy but when I road tune WI maps Delta Dash will log AFRs leaner than 11.24.
When I say I don't know if it is accurate keep in mind 2 things:
1. the WRX front O2 is kind of a quasi WB but not a true one and from my understanding which could be wrong the stock ECU only uses it in closed loop fuel control where it would never run that rich - so it stops using the signal long before it gets to 11.24
2. reading a wideband involves some conversions of a couple signals not just reading the voltage level - just saying it is complex
My assumption though is that ECUTEK has researched the sensor's accuracy and limitations and tested it as well as their conversion logic and left a conservative distance from when it becomes inaccurate for when they lock the conversion at 11.24.
turboICE is offline   Reply With Quote
STL or IN delta dash T3/T4 WRX Mid West Subaru Owners Club Forum -- MWSOC 2 09-26-2003 03:46 AM
Anybody in SE MI have Delta Dash 2000vfr800 Mid West Subaru Owners Club Forum -- MWSOC 0 01-23-2003 04:56 PM
Anyone In Dallas Have A Delta Dash? nickgomez Texas Impreza Club Forum -- TXIC 5 11-29-2002 12:17 PM
Anyone have Delta Dash in ATX/SATX? TypeC Texas Impreza Club Forum -- TXIC 0 07-22-2002 06:49 PM
Anyone in tri-state with a Delta Dash?? alfriedesq Tri-State Area Forum 0 05-12-2002 07:36 PM
