Old 08-10-2003, 09:31 AM   #1
rvanbran
Member#: 6687
Default Replacing Head Gasket
What parts (beside a head gasket) do I need to replace a headgasket on a '98 EJ25 ?
Is this a difficult job to do ? The engine is already out of the car.
Do I need to degree the cams ? Or is there a way to lock them in place while I put the gasket on ?
Thanks,
Rob.
rvanbran is offline   Reply With Quote
Old 08-10-2003, 04:43 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Cams have to come out on the DOHC heads in order to get to the headbolts. Good thing the motor is already out. It'll be much easier that way.
Have fun,
Jay Storm
www.sourcemotorsports.com
Old 08-11-2003, 01:47 PM   #3
svx_commuter
Member#: 41373
1997 Impreza
The T-belt has to come out. The Haynes manual will give you some idea. The head will have to be checked for flatness and cracks as well as the block. It is about as major of a job as can be done without pulling the block apart. Why is the head gasket leaking? Did the engine overheat?
svx_commuter is offline   Reply With Quote
Old 08-12-2003, 07:04 PM   #4
minix42@
Member#: 548
'98 Impreza RS
dinged up faded black
'cause it's a '98... They all go eventually.
mike
minix42@ is offline   Reply With Quote
Old 08-12-2003, 08:59 PM   #5
joemamad
Member#: 27269
Default head job
Hey, this is joe from Pa. Last november I replaced the head gaskets on my '97 ouback EJ25, DOHC engine. Search under my login name joemamad for the posts. By the way the front main seal "fix" I tried is holding up very well, no leaks! (see post) good luck take your time and be thorough, Shell be better than new when your finished. This new gasket is my third in two motors and it is lasting the longest so far.
joemamad is offline   Reply With Quote
Old 08-12-2003, 09:12 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Make sure both surfaces are undamaged/smooth. If you have to get it machined!
Old 08-13-2003, 07:15 AM   #7
svx_commuter
Member#: 41373
1997 Impreza
Default Re: head job
Originally posted by joemamad
.............This new gasket is my third in two motors and it is lasting the longest so far.
That really does not sound to good unless you are racing.
Old 08-13-2003, 07:17 PM   #8
joemamad
Member#: 27269
Default head jobs
Not racing on the track, just driving pretty fast a-lot. Sombody's got to show that these little wagons can fly! In my defense, the head gaskets have been redesigned since the first two blew and I was meticulous in the reassembly. I didn't bother to open up the first engine, just bought a used one and droped it in. I wasn't going to buy another in the end the price was close but I could be sure of what is going on in there.
To reply: yes I do drive fast and hard but not any more so than I have in various other cars. This one is the most fun and I haven't blown any other gaskets or engines unless you count that time.....
Need to replace head gaskets, any help in central Mi..? Aaron'z 2.5RS Mid West Subaru Owners Club Forum -- MWSOC 5 02-27-2007 10:10 PM
Replace head gaskets w/ motor in the car? j rod Normally Aspirated Powertrain 14 08-31-2006 04:18 PM
Another Question on replacing Head Gasket Mike1967 Normally Aspirated Powertrain 26 03-19-2006 06:03 PM
Replacing Head Gasket JakeMandell Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-01-2006 09:12 PM
('93-'01) replacing head gaskets GTkrockett Impreza Forum 4 10-07-2001 04:45 PM
