#1 |
Member#: 41528
Has anyone experienced a problem using the DCCD manual mode while turning at slow speeds? My STI produces a lot of noise and vibration no matter what setting I use while tuning in manual mode. I have tried all the manual settings and it does not help.
I realise that some noise could be produced if the front and rear wheels turn at a slight different rate, but this is excessive. It works fine in AUTO mode and at speeds over 20 miles an hour in Manual mode. I can't believe that this is normal as it makes the manual DCCD almost worthless. Does anyone have an idea as to the cause of this problem?
#2 |
Member#: 31748
Vehicle:'11 WRB WRX Sedan |
look in your manual, it's called torque binding. leave the car in auto mode for everyday driving.
#3 |
Member#: 456
NWIC
Vehicle:2008 Forester XT Steel Gray Metallic |
We really need a newbie FAQ on this.
#4 |
Member#: 37962
Vehicle:2006 CGM STI 2000 Outback & 05 BMW M3 |
If your in manual mode and are doing "parking" type turns and movement, or K turns and such set the DCCD to full open or auto.
#5 |
Member#: 41528
I have read the owners manual. I am talking about excessive torque binding to the point where the entire car shakes when turning at slow speeds everytime. This is not an occasional situation. I find it hard to believe that you can't ever make a slow turn in DCCD manual mode. Does everyones STI perform like that?
#6 |
Member#: 31748
YES, it will happen everytime.
#7 |
Member#: 41528
Thanks for the replies. I appreciate your help in understanding the DCCD. Regards. ESTI
| Thread Tools | |
| Display Modes | |
| o5 sti dccd problem w/ abs, ebrake, dccd and speedo | krambte79 | Factory 2.5L Turbo Powertrain | 28 | 03-19-2012 09:57 AM |
| Need HELP: DccD Problems.. Center Diff?? Rear Diff?? Dccd Controller? | NotoriousD | Transmission (AT/MT) & Driveline | 4 | 06-16-2006 04:26 PM |
| Possible DCCD problem | DONAUDI | Transmission (AT/MT) & Driveline | 7 | 08-22-2005 09:18 PM |
| DCCD Problems | Subycharged | Transmission (AT/MT) & Driveline | 0 | 04-12-2005 12:38 AM |
| DCCD Problems | Subycharged | Transmission (AT/MT) & Driveline | 0 | 04-12-2005 12:37 AM |
