Welcome to the North American Subaru Impreza Owners Club Monday July 28, 2014
Old 08-10-2003, 12:25 PM   #1
D-Rock
Member#: 3651
2001 2.5 RS Coupe
Default A/C and water out of floor vents
I was driving my 2001 RS the other day and took a sharp turn. When taking the turn water started comming out of my floor/heating vents. This only seems to happen if I've been running the AC.
Any tips on what this could be? Could I fix this myself?
D-Rock is offline   Reply With Quote
Old 08-10-2003, 12:31 PM   #2
Karl
Member#: 13110
Your a/c drain line is clogged for some reason. Try to locate it and see if there is blockage.
Karl is offline   Reply With Quote
Old 08-10-2003, 03:07 PM   #3
D-Rock
Member#: 3651
2001 2.5 RS Coupe
Any hints on where the A/C drain line is located or how to get to it?
Thanks for the help!
Old 08-10-2003, 04:37 PM   #4
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
The air system should be behind your glove box/center dash area. On '02s, I believe the outside air is sucked in behind the right side of the glove box, goes through the "cabin air filter", and then goes left to the A/C cooling unit (not sure what it's officially called). There should be a hose coming out of the bottom of that unit, and going down and back, with its opening underneath the car.
I would strongly recommend buying or looking at a shop manual if you want to get at the insides of the unit that has the drain hose. If you just want to try unplugging the hose a bit, jack up the car onto jackstands, crawl underneath, find the drain hose opening, and *gently* run a very narrow pipecleaner type of brush up the tube. You might *gently* try a coat hanger first, being careful not to damage the rubber tube.
Old 08-10-2003, 06:41 PM   #5
Keith99RS
Member#: 9243
05 Nissan Titan
06 B9 (hers)
Has it only done the water out of the vent thing recently? My RS did it for the first time last weekend. Just a drip or two on my wifes leg. It never did it earlier in the year. For now I have written it off as the AC drain not being able to keep up with the ungodly humidity we have been having in CT (not sure about NH) for the last two weeks. I'll keep and eye on it when the humidity drops back to reasonable levels.
Keith99RS is offline   Reply With Quote
Old 08-10-2003, 09:32 PM   #6
CRS_Unknown
Member#: 40257
I too would like to know where that drain is and how to unclog it. I have a major puddle from using the a/c through that humidity. Then it rains every night so crawling under hasn't happened. But you gotta run that a/c when stuck on 93 every night.
CRS_Unknown is offline   Reply With Quote
Old 08-11-2003, 07:02 PM   #7
D-Rock
Member#: 3651
2001 2.5 RS Coupe
Well I think I fixed it. Tonight I'll try running the A/C for a while to make sure it's draining properly.
I had my car up on jack stands and searched all over heck for the drain line. I had tried a couple times with no luck. I ended up locating it while looking under the hood. The A/C drain line came out of the passanger side at the bottom of the firewall. It was hanging above the catalytic converter.
To clear the drain line I used my air compressor and blew air up the tube. Sure enough I could hear water bubbling. After blowing air up the drain line the water started flowing out.
Thanks again for the help!
Old 08-11-2003, 08:57 PM   #8
svx_commuter
Member#: 41373
1997 Impreza
I ahd the same problem on my OBS and fixed it the same way. Blew compressed air up the drain hose.
svx_commuter is offline   Reply With Quote
Old 08-11-2003, 09:02 PM   #9
CRS_Unknown
Member#: 40257
Thanks for the tips and i will give it a try when things dry up. around 90 degrees and humid again today in Boston so I guess no relief yet!!
Smoke out of AC vents? progresr Service & Maintenance 12 11-18-2004 05:46 PM
getting water out of my ears? tlatoani Off-Topic 10 06-01-2004 03:07 PM
Why does my the air come out of the vents so hot? Zoso Newbies & FAQs 19 12-12-2003 11:49 PM
hot air comming out of cold vents/fixed kb3drfsti Factory 2.5L Turbo Powertrain 0 11-04-2003 05:12 PM
Scooby and Water... LOTS of water wolve80 General Forum Archive 14 07-21-2000 03:59 AM
