Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 05-26-2001, 01:48 PM   #1
FletchMY98
Member#: 6395
2006 WRX STI
Steel Grey Metallic
Post
* Its not WRX engine. Its out of a Liberty RS.
* Its an automatic. Expensive and complicated to convert to manual.
This engine was virtually identical to the first Impreza turbo engines fitted into UK cars from 94 on - the only difference was air/air intercooler rather than water, and 14psi boost instead of 12psi on the Liberty. It has the water/air intercooler, which is a dead giveaway. It also has hydraulic lifters (renowned for being a bit rattly!)
IMHO - You'd be better off looking for a different engine if you want to do an engine swap, unless you want an auto...Then it might be a good option for you.
Hope this helps.
Chris
FletchMY98 is offline   Reply With Quote
Old 05-26-2001, 01:54 PM   #2
oldpreza
Member#: 5259
1995 Impreza
Post
wait, so is it hard to bolt on a EJ22 turbo from a 91-94 USDM Legacy into a manual trans? Most of the legacys are auto.
oldpreza is offline   Reply With Quote
Old 05-26-2001, 02:53 PM   #3
Xeno
Member#: 3426
2007 STi
Post
ahh the memories..i miss my libby.. all 250 Hp of her.. bullet proof engine.. never a problem with it.. *sigh*.. RIP libby
<IMG SRC="http://zate.dyndns.org/wrx/lib2.jpg" border=0>
1992-2000 - RIP
Xeno is offline   Reply With Quote
Old 05-26-2001, 04:29 PM   #4
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Post
Did you see that intercooler! Air/Water BABY!
djerickd is offline   Reply With Quote
Old 05-26-2001, 05:52 PM   #5
XT6Wagon
Member#: 524
04 STi
Post
Why would it be hard to convert to a manual tranny? The subaru engines have allways been able to mate to BOTH autos and manual trannies. Its the BODY of the car that is a problem, but if you use the stock tranny in your legacy or impreza it should work fine.
However I might point out that this engine doesn't seem to have any of the accessories with it, and I don;t know if the ones off the old engine will bolt on. You also will be stuck trying to get the stock ECU to deal with the motor, which may or may not be difficult.
XT6Wagon is offline   Reply With Quote
Old 05-26-2001, 06:04 PM   #6
JC
Member#: 692
2011 Grand Cherokee
Triumph Speed Triple R
Post
Xeno, I had the same rims on my '93 Legacy.
oldpreza, what happend to not needing a lot of power? haha
JC is offline   Reply With Quote
Old 05-26-2001, 07:43 PM   #7
oldpreza
Member#: 5259
1995 Impreza
Post
XT6: good point about the accessories. I think the seller said that there's no alternator, starter or power steering pump.
JC: i need a little more power.
To think of it, this might be a bad buy for the sake of ease to find parts and information.
Old 05-26-2001, 07:50 PM   #8
JC
Member#: 692
2011 Grand Cherokee
Post
There are lots of parts and info on the EJ20, probably more than there is for the EJ22 and EJ25. Your car would be damn fast if got that engine.
JC
P.S. I saw you driving to the theatre on friday.
Old 05-26-2001, 09:51 PM   #9
Jessie James
Member#: 2072
Post
There is NO WAY that engine has 30k - 40k miles on it.... look at the rubber CV joint boots. They are destroyed.
That engine probably has 80k miles or more on it.
Buyer beware!
Jessie James is offline   Reply With Quote
Old 05-27-2001, 12:03 AM   #10
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
Post
the seller has like 6 import motors, they all say the same thing,30-40k miles, even though are around 7 years old or more..be sure you can get the computer and wireing for it...
bobjr94 is offline   Reply With Quote
Old 05-27-2001, 12:09 AM   #11
oldpreza
Member#: 5259
1995 Impreza
Post EJ20 turbo for sale on ebay (comments pls)
http://cgi.ebay.com/ebaymotors/aw-cg...743172&r=0&t=0
anyone has comments on this engine or the sale in general? thanks.
Old 05-27-2001, 11:19 PM   #12
PERRIN
NASIOC Manufacturer
Member#: 6776
Post
there are a lot better deals out there than this one. i found a bunch of people who import these engines to the US. i got a Liberty motor with the watercooled intercooler and i can keep my air temps to 50-80 degrees. I would not worry about the manuel to auto thing, just use your existing tranny. as for running it, deffinatly don't buy the ECU, they will want to much and then you will have to deal with the wiring. If you are going to go thought with this i would buy a Stand alone ECU, make sure that you get the downpipe and all the wiring plugs and sensors you can and the intake if possible. the alternater and the starter from you car will also work on the engine.
PERRIN is offline   Reply With Quote
Old 05-28-2001, 01:36 AM   #13
apexwrx
Member#: 4111
02 GDB WRX STI
Post
I have 2 ej20 front clips, one an sti version 95 and the other is a standard version 95.
interested?
milo(apexwrx)
apexwrx is offline   Reply With Quote
Old 05-28-2001, 09:12 AM   #14
PERRIN
NASIOC Manufacturer
Member#: 6776
Post
how much???
Twin turbo clip for sale on ebay... gtwagon941 Legacy Forum 0 09-29-2004 05:32 PM
Twin turbo ferrari for sale on ebay HalfBaked Off-Topic 22 09-19-2004 08:10 PM
Factory 2.0 EJ20 Turbo For Sale Ravenous Private 'For Sale' Classifieds 0 05-11-2004 07:22 PM
New EJ22 turbo shortblock for sale on ebay morpheous Private 'For Sale' Classifieds 6 10-07-2003 05:08 PM
Legacy Turbo for sale on Ebay Not me MugenNeuspeed Legacy Forum 1 10-07-2002 12:02 AM
