Old 08-10-2003, 07:45 PM   #1
batmanalan
Member#: 37583
Default cobb question...MORE POWER
What can i do after i have the cobb stage 2, w/ uppipe and turboback?
i want more power, but don't want to make my reflash useless, and keep the stock turbo.
Any recommendations
ie. ic hoses? etc.
thanks in advance,
alan
batmanalan is offline   Reply With Quote
Old 08-11-2003, 01:34 AM   #2
oman
Member#: 9293
java black pearl
You could probably push the car to be a little bit more aggressive with an upgraded intercooler and a custom dyno-tune.
Other than that I'd say you're SOL unless you get a bigger turbo.
BTW... this should be in Factory Forced Induction
oman is offline   Reply With Quote
Old 08-11-2003, 10:24 AM   #3
Nitro Don
Member#: 19820
2007 NINJA ZX-10R
batmanalan,
I'm at the same level your at Cobb stage2-up/down pipe- catback-pulleys.
I ordered a set of Samco IC hoses. You could try that and some pulleys.Maybe port and polish stock turbo?Is there any benifit to going with a larger IC on stock turbo?
I think thats about it. I'm just wanting for Cobb to release the VF-30 reflash.So hurry up and release it!
Don
Nitro Don is offline   Reply With Quote
Old 08-11-2003, 03:27 PM   #4
bunot
Member#: 21641
4EAT [email protected]
Now a 6MT! beyatch!
NAAAAWWWZZZZ!!!
jason
bunot is offline   Reply With Quote
Old 08-11-2003, 03:33 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i would agree hoses and pulley ... but as oman is the wrx ecu master hacker he would know better than most
Old 08-11-2003, 04:37 PM   #6
oman
Member#: 9293
java black pearl
NO... that is INCORRECT
If you want to make your ECU play checkers then I'm the man to talk to. If you want to make your car go fast then you need to talk to Trey or Josh here at the shop.
Not a week passes where I don't say something like,
"I need to do blah and blah to my car."
and Trey is like,
"Uhmm... no.... that's a bad idea."
and so on
I'm learning tons tho
Old 08-11-2003, 05:03 PM   #7
batmanalan
Member#: 37583
the downside of pulleys is just way to great for what it does...
i guess i have to keep searching, or just be happy w/ it.
alan
Old 08-11-2003, 06:45 PM   #8
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
What downside? There are only two "problems" I have heard about with them. The Vishnu underdrive set can cause problems. If I remember correctly, they make/cause/fool the car into pinging. This only applies to Vishnu's pulleys and not everyone with their pulleys has this problem. The other one is that it can cause a false rev limiter on an aftermarket ECU such as Cobb's. This can be quickly seen/felt and can be fixed by putting the stocker back on. This problem is NOT brand specific and applies to all makers of lightened and underdriven pulleys. Worst case is you are out $20 or so if you have to sell it. Is there another problem you are referring to?
P.S. Oman, I assume you work for Cobb....if so, you will be seeing my ECU tomorrow!
Ron
Old 08-11-2003, 09:41 PM   #9
batmanalan
Member#: 37583
ive just heard of them underdriving the utilities, causing to problems, i did a search and no one seemed really hapy w/ them. Al dustin at buzz off also told me they are not worth it...jsut numerous opinions, so i guess all i can do is ic hoses.
alan
Old 08-12-2003, 12:26 AM   #10
Brad B.
Member#: 10292
2002 WRX Sedan
I'm in the same boat as you guys.
I have a Godspeed Uppipe/ Godspeed Downpipe, custom mid-pipe, Prodive axel back, K&N drop in, Vishnu IC hoses, Vishnu Main Power Pulley (no issues, I'm lucky?), TurboXS MBC and removed intake silencer.
I'm looking at ditching the MBC and getting a Cobb (or similar) reflash. But I'd like a definate answer on whether or not at VF30 map is going to come out. If it is, I'll get a Stage 2 reflash now, then send mine back in for a 2nd reflash when more maps are out. (a 2nd reflash from Cobb is only $20!!)
Brad B. is offline   Reply With Quote
Old 08-12-2003, 12:35 AM   #11
Nitro Don
Member#: 19820
2007 NINJA ZX-10R
Brad B.
I have heard that the VF-30 reflash is soon to be released,but I dont know when.You can always go out to Cobb for a custom flash.
I can wait cause I still need time to save up for the turbo and injectors anyway
Old 08-12-2003, 01:25 PM   #12
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
There is a local guy with Cobb Stage 2 reflash & one of Mr. Josh's lightweight non-underdrive crank pulleys with zero issues & tons of pull!!!!
I/C hoses will help, but not that much when you're already at the level you're at. Pulley is the same too, minimal increases unlikely to be that noticable. If it isn't enough & you aren't wanting to change turbos... Call Cobb. They could probablly offer up a I/C upgrade & maybe mate & intake to it & offer you a different reflash. I know intakes don't do much, but I did hear Cobb does have maps for most intakes on the market upon request, but not advertised on their site.
At the point you're at... turbo upgrade, I/C upgrade, Injector upgrade is really the only 'big gain' option.
omahasubaru is offline   Reply With Quote
Old 08-12-2003, 11:07 PM   #13
Vegumkoho
Member#: 12059
2002 WRX Blue
Wish all roads were dirt
I seem to remember someone at a similar level as all of us that got a custom tune, that the stock intercooler was holding things back a bit. I would call Cobb and see what they say though.
Vegumkoho is offline   Reply With Quote
Old 08-13-2003, 02:09 AM   #14
triguy
Member#: 27109
2002 WRX Wagon
2.5L Crawford, 6 spd
Default Cobb Stage 2
I have the stage 2 and IC hoses and Vishnu underdrive pulley and no issues with the pulley. Both are relatively easy mods and provide noticeable benefits.
triguy is offline   Reply With Quote
Old 08-13-2003, 12:42 PM   #15
batmanalan
Member#: 37583
according to my recollection; the hoses just help boost spool and maybe give 5 hp, am i correct.
Just like to hear it from someone who has them.
thanks again
alan
Old 08-14-2003, 07:39 AM   #16
Nitro Don
Member#: 19820
2007 NINJA ZX-10R
My Samco IC hoses should be here today
I'll have to install them and see if there is any seat of the pants difference.I heard about 8HP with hoses.
I've had my GFB pulleys in for about a year now.With the stage2 I haven't had any problemswith them.
Old 08-15-2003, 06:23 PM   #17
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
water injection is also an option for you guys. Although to take full advantage of it, you'd need a custom tune. Where's accesstuner?!
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Blouch, Cobb, Perrin, Agency Power, Subtle Solutions & MORE!!! Annapolis Subaru Engine/Power/Exhaust 7 01-18-2010 09:53 AM
who thinks that cobb should make another map that should make our cars more power 949 Engine Management & Tuning 18 03-30-2005 02:35 AM
cobb 2.5 + protuner for more power bren wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 02-14-2005 05:48 PM
Turbo Legacy question. More power. Spade Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-29-2002 12:42 PM
