Old 08-10-2003, 07:53 PM   #1
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Default ? about towing a wrx behind a motor home
AWD Subaru vehicles with manual transmission can be towed with all four wheels on the ground and the transmission in neutral. AWD Subaru vehicles with automatic transmission can only be towed with all four wheels OFF of the ground. Therefore, if you are interested in towing a Subaru behind your motorhome, we would suggest purchasing a manual transmission Subaru.
That is a quote from www.subaru.com. My question is, has anyone here actually done it? I have a manual transmission but am some what concerned that if I tow it and something goes wrong they will blame it on the fact that I have mods.
LiquidForce is offline   Reply With Quote
Old 08-11-2003, 04:53 AM   #2
dubRexn
Member#: 16100
GD
This won't help but a guy towed his manual wrx and forgot to take it out of gear, and destroyed his engine and tranny, costed him over 10K in repairs.
So I don't think it will be a problem with the car in neutral, good luck
dubRexn is offline   Reply With Quote
Old 08-11-2003, 10:14 PM   #3
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
You should be fine but if you are really worried and want to reduce the wear on the car you will need a flatbed trailer.
Mike Wevrick is offline   Reply With Quote
Old 08-12-2003, 03:24 PM   #4
kidatari
Member#: 10441
The 4WD guys that tow their rigs to trail runs and whatnot typically unbolt their rear driveshaft, and unlock their front hubs, so that the tranny isn't spinning while the vehicle isn't bieng towed. Basically, you could do the same thing, and remove the front axles and disconnect/remove the rear driveshaft, if you were so inclined. But that's a heck of a lot of work if you're not just towing it cross country.
kidatari is offline   Reply With Quote
Old 08-12-2003, 06:22 PM   #5
Zack
Member#: 41126
2000 Miata
Emrald Mica
Find someone to drive the RV. Or get a trailer... I don't supose a cheap used trailer can be too much. Besides you'd look more like a pro.
Zack is offline   Reply With Quote
Old 08-13-2003, 09:35 AM   #6
LiquidForce
Member#: 12811
2002 2.5l Wrx
Thanks for the replies.
I found someone who uses a WRX as a "toad" behind his rv. He seems to not have any issues. The only problem I have now with towing is that to do it right I need base plates added. These will protrude slightly from the grill so the towbar can hook up. Another 50lbs forward of the wheels should really help the understeer
Since I like to do track days (the reason I am towing), I dont think I'll go this route. A trailer it is for me.
Old 08-13-2003, 08:46 PM   #7
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
a halfway decent flatbed trailer can be bought for about $2000-$3000 new, used is far less.
ChrisW is offline   Reply With Quote
Old 08-14-2003, 12:17 AM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
good choice...get the trailor and save your tranny and diffs!
quick random question about towing a car behind rv's stg2wgn General Community 11 07-23-2009 10:26 AM
question about towing a subaru TSILVEY Transmission (AT/MT) & Driveline 11 05-17-2009 11:05 PM
