#1 |
Member#: 2003
Vehicle:'99 BGP Legacy GT '98 QS Legacy L (auto) |
I just heard that the guys @ JC Sports have made a air-intake system for the new WRX's!
So for those looking for getting some more power "relatively" cheaply, something to look into. Definately gives you more power vs. just a panel filter.
#2 |
Member#: 477
Vehicle:GC4 -> GGA -> GM6 Yeah, that's about right. |
Awesome, let's see some dyno charts!
#3 |
Member#: 3792
Vehicle:2002 6MT almost GDB |
I hope so because I will be one of the first to buy one. That is step one to "MORE POWER"!!!
#4 |
Member#: 191
NESIC
Vehicle:2012 J train Brown |
i have never heard anything good about JC sports though, last I heard they are still screwing ppl over in the turbo gb, this is fairly common from what I hear.
Although, it is nice that they have new toys, I wouldn't send them my money Just a heads up ![]() keith |
#5 |
Member#: 442
NESIC
Vehicle:2013 Crosstrek XV 00 Honda S2000 |
JC Sports? They're still around?
Bashing begins under this line ---------------------------- |
#6 |
Member#: 456
NWIC
Vehicle:2008 Forester XT Steel Gray Metallic |
All I can say is, it had better have a cold air intake.
#7 |
Member#: 4218
I agree with Glenn, you definitively do not want your engine to get air from under the hood. The turbo heats that air fairly well and you will loose power if the intake is not a cold air one.
#8 |
Member#: 3389
Vehicle:07 STImpreza Satin |
Not really, a block off plate would do well, but just plain open would still make more power. I would not do it though, you get more air more power, but it will be hot air=increased likely hood of detonation.
A true cold air intake is the way to go. Ken |
#9 |
Member#: 2003
I'll keep you guys posted when I hear more about it. It's suppose to be a CAI for the WRX.
Actually, JC Sports quality is really good, only they are lacking resources for customer service. |
#10 |
out back
Moderator Member#: 1964
RMIC
Vehicle:01 BH Blue/Bronze |
You must remember this one thing:
Intercooler. The temperature of the intake BEFORE the turbo is insignificant to its temperature AFTER the turbo, there's is heated by compression and ambient temperatures. If the Intercooler is working properly, it really makes almost no difference whether its cold-air or otherwise. Point: Byron's EJ22T Impreza with 500+ hp has an underhood intake with a blocking plate. |
#11 |
Always under your radar!
Moderator Member#: 1568
Isn't JC Sports banned to promote or sell on this board???
If this is true, just be careful GTBGUY! Don't want to see you caught up in stupid messes like this... ![]() |
#12 |
Member#: 300
NESIC
Vehicle:2002 WRX Aspen White |
Here it is... looks pretty nice, as does most of their stuff. Too bad their customer service is "suffering". Looks good though, no price yet.
<IMG SRC="http://www.jcsportsinc.com/web/images/wrx_intake_xlrg.jpg" border=0> |
#13 |
Member#: 329
Vehicle:1995 325i Arctic Gray |
Haha, that's one funny looking intake
. It must be a PITA for whoever applies those JC SPORTS decals to their intakes, especially since a lot of people peel them right off when they get them . |
#14 |
Member#: 3382
Vehicle:2001 Impreza RS Black, like me |
Lets do a group buy!
#15 |
Member#: 329
Youngun, why would you want a WRX intake with your 2.5RS? Unless you're giving it to me?
#16 | |
Member#: 1575
South East
Vehicle:2011 WRX Premium Blackest Black |
SO: Z+X-Y = final intake temp If you lower Z and keep everything else the same You get a lower intake temp (dense air charge). |
#17 |
Member#: 442
NESIC
Hmm that pic of the intake won't work with a WRX...
There's no place for the MAP/S/F to hook into. --kC |
#18 |
Member#: 3967
Youngun'
HA,HA ![]() |
#19 |
Member#: 300
NESIC
the MAF sensor is smaller and "modular" like the ones on the new Celica. That square boss welded onto the tube gets the sensor.
#20 |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
Skid, this is not quite true.
The efficiency of a heat exchanger (intercooler) will go up as the tempurature difference is increased. So, as the temperature of the air being expelled from the turbo is increased, the intercooler will become more efficient, and the temp drop across if will be greater. Depending on the system and how good the intercooler is to begin with, it's conceivable that there would be no difference in engine intake temp for a temperature increase at the filter. In addition to this, the temperature gain of the intake is caused from the compression of the gas. The effect of the original intake temperature is going to be partially 'masked' by the effect of the gas compression. So the way I see it, original intake pressure may have a small effect on the ultimate power of the engine (when the turbo is at full boost,) certainly less significantly than an N/A car. It will also be considerably less significant when at anything less than full boost, as the free breathing helping the turbo spool faster will be a bigger help. Cold air is a bonus, but free breathing is the more important factor, I think. |
#21 |
Member#: 2003
#22 |
Member#: 2003
BigElm - thanks for the concern bud
IIRC, they are banned until the GB for the turbos are done.... at any rate, I don't work for them so it should be ok? ![]() |
| Thread Tools | |
| Display Modes | |
| J's Graphics - Gauging some interest + looking for some ideas for new stickers | Don Nguyen | Interior & Exterior Modification | 11 | 10-13-2009 12:20 PM |
| some mod info for 06 WRX | inpuressa | Newbies & FAQs | 5 | 02-16-2007 11:44 AM |
| Some VF35 info for you if you're interested | sherifx | Factory 2.0L Turbo Powertrain | 3 | 09-10-2002 08:30 PM |
| Update on my FPR stuff. some interesting info inside. | Eric SS | Normally Aspirated with bolt-on Forced Induction Powertrain | 0 | 06-10-2002 10:39 PM |
