Old 08-11-2003, 12:07 AM   #1
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Arrow Rear Wheel Bearing TSB 03-50-02
http://www.endwrench.com/current/Cur...s/03-50-02.pdf
My guess is that's WTLW but I thought I'd post it here anyway in the event someone missed it.
Peaty
Peaty is offline   Reply With Quote
Old 08-11-2003, 12:11 AM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Hi Peaty and bump !
Brian
Old 08-11-2003, 04:15 PM   #3
subiejen
Member#: 41603
98 Outback Sport
Green
Default Wheel bearings
Hi-ya!
I see that there are many postings concerning wheel bearings. I'd like to add another to the long list.
I have a 98 Outback Sport. I love it but I'm tired of the "off balanced washing machine" or "rocks in a cement tumbler" sound from my rear. I've replaced both of the rear wheel bearings at 25k 49k and now again at 73k. Besides making sure the techs pack the darn things with grease, is there anything else I can do? Upgrade? Purchase another company's bearings? Or should I just bring it in every 20k for a bearing change?
Also, does anyone think the suggestion that a 4 wheel alignment be done after the bearings are reinstalled makes sense? I can't seem to get enough info from my tech guy.
Thanks for letting me piggy back your posting =)
subiejen is offline   Reply With Quote
Old 08-11-2003, 04:36 PM   #4
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
What happens is if you install them wrong you distort the hub or something that holds the bearing. Then every new bearing you install after that is messed up and will not last very long.
Old 08-11-2003, 07:08 PM   #5
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
The other thing that happens far too frequently with independent repair shops (and sometimes Subaru shops ) is that the installer assumes the light packing grease in the bearing is a prepacked bearing, which simply isn't the case. Bearings installed that aren't cleaned and packed don't last very long either .
Brian
Old 08-11-2003, 09:57 PM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
Hopefully, repair shops (including Subaru dealerships) will ignore the advice offered above and instead follow the instructions found in the cited TSB:
The new genuine Subaru rear wheel bearings are not to be packed with grease of any kind. The bearing is ready to install out of the box.
Jon [in CT] is offline   Reply With Quote
Old 08-11-2003, 10:22 PM   #7
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
The TSB is pretty new and they just changed the procedure. Mostly because what Brian described happened too often. People would not repack when they were supposed to
Look here:
http://www.endwrench.com/pdf/drivetr...nsiderInfo.pdf
The first paragraph talks about the bearing issue. How the housing can get deformed and cause failures also about repacking the bearing because the grease they come is not the proper stuff.
Old 08-11-2003, 11:01 PM   #8
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
If you actually worked in a Subaru shop (as I do) instead of just taking what Subaru prints as verbatim, you would see the bearings come in with light packing grease, not bearing grease, and see for yourself the need for repacking. Plug come pregapped and don't ever need to gapped too, right ? I can take photos if you are in need of them . In a perfect world, Subaru publications would be correct all the time, but in the real world, things are not always so rosey, and Subaru updates their proceedures more often than many people change their socks .
Brian
Old 08-12-2003, 10:27 AM   #9
subiejen
Member#: 41603
98 Outback Sport
Green
Okay, besides packing with grease, or not packing, would a 4 wheel alignment help?
Old 08-12-2003, 10:36 AM   #10
Jon [in CT]
Member#: 2992
02 WRX Sedan
Great. How about some pix of part number 28016AA030?
Old 03-04-2004, 04:37 PM   #11
clyde
Member#: 14305
1997 Impreza OBS
Bump for photos of the new bearing? It seems I'll be facing a bearing replacement under a warranty from an indepenant shop, and I'd like to furnish the best information I can so that it lasts more than 10k this time.
clyde is offline   Reply With Quote
Old 03-04-2004, 05:58 PM   #12
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
They don't look physically any different from the outside. A photo isn't going to help your shop. Just get 28015AA050, 28015AA100, 28015AA110, and 28016AA030 if it's a rear bearing and 28015AA021, 28015AA071, and 28016AA011NT if it's a front bearing. Make sure you remind them to repack the bearings before installing.
Brian
Old 03-04-2004, 06:47 PM   #13
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
Definately Re-pack those bearings. Ignore what SOA says. Every bearing that we repack has never failed. Yet when we do get a repeat failure it always has the original grease in it. Coincedence??
Old 03-04-2004, 09:12 PM   #14
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
I think not
(I know you were waiting for it )
Brian
Old 03-04-2004, 09:29 PM   #15
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
I think not
Brian
Old 03-05-2004, 09:04 AM   #16
Jon [in CT]
Member#: 2992
02 WRX Sedan
I love it when dealer parts counter guys and service techs decide they know better than the factory engineers.
In addition to TSB 03-50-02 New Procedure for Replacing Rear Wheel Bearings, which explicitly warns that grease should not be added to the new tapered roller bearings, SOA also issued a new version of the booklet Wheel Bearing Installation Guide. It is MSA5TT0201 and can be downloaded from http://www.endwrench.com/current/Cur...MSA5TT0201.pdf. On page 9 of that Installation Guide, there is this warning in bold:
Old 03-05-2004, 09:20 AM   #17
clyde
Member#: 14305
1997 Impreza OBS
Yeah, seeing that in every subaru document I could find is what made me want to make sure these repacking suggestions were up to date. A statement like hondaslayer makes carries a nontrivial emperical factor, though (at least in keeping with as broad and thorough as one believes his data sample to be.). I'd be interested to hear it repeated or not by people from other shops.
Also, what kind of grease are you guys using to repack? I'm only about 80% through my searching here, but so far I see only a lot of "most expensive synthetic you can buy" and "neo". Need it really be some exotic neo/motul/amsoil/redline stuff, or would something from the local rice department store be a reasonable choice?
(What's wrong with the subaru grease anyway? Is it categorically insufficient by virtue of being nonsynthetic? Is it a temperature thing?)
Old 03-05-2004, 11:05 AM   #18
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Uh huh. And I love it when people with no real-world experience with these items plays Monday morning quarterback to apparently make themselves feel better or more superior- I really can't understand your motivations sometimes Jon . You can read books and press releases all day, but when it comes right down to it, if you don't repack the bearing, it will fail.
Brian
Old 03-05-2004, 11:15 AM   #19
Jon [in CT]
Member#: 2992
02 WRX Sedan
... but when it comes right down to it, if you don't repack the bearing, it will fail.
Why don't you just call the Subaru Tech Line and see whether you can get them to confirm that their most recent wheel bearing documents are flat out wrong?
Let us know what they tell you.
Old 03-05-2004, 11:23 AM   #20
clyde
Member#: 14305
1997 Impreza OBS
Not to get off topic here, but does anybody have anything to say about what one should be looking for in a replacement grease (and why, if there remains any interest in an illuminating discussion)?
Old 03-05-2004, 12:39 PM   #21
Jon [in CT]
Member#: 2992
02 WRX Sedan
If you're still messing with the old style rear bearings, then Subaru specifies Shell 6459N grease.
However, if you're installing the new style rear bearings described in TSB 03-50-02, you'll loose your Subaru Genuine Replacement Parts Warranty (1 year) if you fail to follow the procedure defined in the new Wheel Bearing Installation Guide, MSA5FF0201. As noted above, that Guide warns "Do not add any grease to the bearing."
Also, SOA has required since Jan 2, 2003 that all rear bearing warranty replacements be performed using the procedure defined in MSA5TT0201. If I were North Ursalia or hondaslayer, I wouldn't be advertising that my dealership's service department was willfully ignoring that installation procedure. SOA might just decide to un-reimburse the dealership for those repairs.
Old 03-05-2004, 10:53 PM   #22
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
Jon,
If you have evre called SOA techlines you would realize that they are damned near useless. When I have trouble I call my local SOA teacher. He can always get me out of a jam,and 99% of the time he will say something completely opposite of techlines. And guess which is usually right? Book? Or real world experience?
"I'll take real world for $500 Alex"
Old 09-30-2005, 12:24 PM   #23
GotWRX03
Member#: 35705
Do you have a link to a good "how to" directions (like the one stated above) on how to replace the front bearing? I'm about to replace mine next weekend.
GotWRX03 is offline   Reply With Quote
Old 09-30-2005, 01:33 PM   #24
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
***popcorn**
Acostafan is offline   Reply With Quote
Old 09-30-2005, 01:41 PM   #25
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
You could try searching around endwrench there might be something else
www.endwrench.com
FS:NC: New Rear Wheel bearing 02 WRX Rando Suspension/Brakes/Handling 13 11-01-2009 05:58 PM
(New) Walbro Fuel Pump, Falken ZE-912 215/50/16 Tires, NTN Rear Wheel Bearing 05Subie SCIC Private Classifieds 7 02-12-2009 04:21 PM
Help! >< ,02 rear wheel bearing remover puller tool bon1210 Brakes, Steering & Suspension 2 03-27-2008 04:30 PM
02 Rear Wheel Bearing Refund? v_dubs37 Brakes, Steering & Suspension 0 01-17-2006 03:50 PM
Any luck with TSB 03-51-02? positivePSI Mid West Subaru Owners Club Forum -- MWSOC 0 02-18-2003 01:46 PM
