Old 08-11-2003, 03:27 AM   #1
NateDogg
Member#: 6467
1999 Impreza 2.5 RS
Default leaking headgasket... so
since im going to have the heads off my car should/could i do anything to the motor/heads to increase performance cheap?
Nate
NateDogg is offline   Reply With Quote
Old 08-11-2003, 12:30 PM   #2
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
Well, if you know how to do portwork you could do a port and polish job, and also port match the intake manifold to the heads. All this will cost is your time and some grinding stones.
DISCLAIMER if you dont know what you are doing when porting you could screw things up majorly, and actually reduce performance. Port matching the intake manifold to the heads is not too hard and will help airflow, there has been a little bit of talk about this recently, there was no consensus about gains, but it seemed to be beneficial. I will be doing a port match when I put my phenolic resin spacers on.
Compressed is online now   Reply With Quote
('93-'01) EJ25 leaking headgasket? kirbykirb Impreza Forum 1 08-23-2009 05:53 PM
headgasket leak at 43k AFY2600 Warranty Issues & SOA Problems 13 01-12-2008 05:46 PM
2.5L N/A: Oil Leak precusrsor to 2.5 Headgasket failure? 99legacyL Newbies & FAQs 0 04-12-2007 03:35 PM
01 forester leaking headgasket robsgotit Tri-State Area Forum 8 11-25-2005 04:56 PM
Deep puddles + STi = HEADGASKET LEAK!! Need some suggestions for stronger motor ;) 300blueballs Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-08-2004 07:26 PM
