Old 08-11-2003, 09:45 AM   #1
ttoversteer
Member#: 465
2012 GTI
Gray
Question Missfire: #4 cyl
My CEL comes on regularly, and every time I read the code it is a missfire on the #4 cyl. Anyone know what might cause this? I could just start throwing parts at it, but I'd rather save the money and just fix the problem.
Thanks!
ttoversteer is offline   Reply With Quote
Old 08-11-2003, 10:11 AM   #2
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
check the sparkplug and wire
tekfoc is offline   Reply With Quote
Old 08-13-2003, 07:32 AM   #3
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
Check for corrosion on the terminal on the coil pack. Also check for a broken plug and / or bad connection on the wire.
spshultz is online now   Reply With Quote
Old 08-14-2003, 02:34 PM   #4
skoobywrx
Member#: 28088
05 WRB STi
06 Outback
my friend had the same problem in his RS
Check your coil when the motor is running, and look for arching, if so, you might need a new coil
skoobywrx is offline   Reply With Quote
Old 08-15-2003, 08:13 AM   #5
TimStevens
Member#: 4817
2012 STI, '02 WRX
'91 MR2, '05 Speed Triple
Had the same problem on my WRX after a rallyX run. Spark plug became disconnected. Reconnected everything and it ran just fine.
TimStevens is offline   Reply With Quote
#4 cyl missfire hoffmanEstates Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 11-02-2008 11:05 PM
Help. Vac line off of TGV on CYL #4 ASAP page02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-12-2007 08:47 PM
No spark on #3 and #4 cyls? w chapman Normally Aspirated Powertrain 1 08-30-2005 05:16 PM
#4 cyl down TyranosaurusWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-29-2005 12:34 AM
hmmm, i think cyl #4 went out on me... latinskllz Normally Aspirated Powertrain 3 07-22-2004 09:59 AM
