Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 08-11-2003, 07:26 PM   #1
ninjaboy76
Member#: 33456
2015 WRX
WRBP
Default o2 sensor for up pipe
I want to know what resistor I need to purchase for the o2 sensor in the up pipe. I know you buy them at radio shack, I just don't know which one. I have a UTEC, and full exhaust system that I need to install onto the car. Do I even need the resistor to install all these things so I don't through the cel from the uppipe? Please HELP!
ninjaboy76 is offline   Reply With Quote
Old 08-11-2003, 07:44 PM   #2
03WRXMA
Member#: 35081
2012 WRX
Please search, its been covered 1,000's of times before....
Its not an 02 sensor in the uppipe, its an EGT sensor.
If your not putting in an aftermarket uppipe, dont **** with it.
03WRXMA is offline   Reply With Quote
Old 08-11-2003, 08:58 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
2.2K ohms.
As stated it is the EGT sensor not an 02 sensor. If you have the factory uppipe with the cat still in place the EGT sensor has an important function, it monitors the cat for overheating. The sensor should be replaced with a working one if it has failed rather than bypassed with a resistor. If you have installed an aftermarket catless uppipe then it is acceptable to use the resistor. In this case if you have not already done so the EGT sensor should be replaced with a bolt inserted in the bung assuming your uppipe has one.
Old 08-13-2003, 06:44 PM   #4
ninjaboy76
Member#: 33456
2015 WRX
WRBP
Default EGT sensor
Thanks for the correction. I have the turbo XS uppipe, a 4" down pipe,a race pipe to replace the stock cat and a 3" catback exhaust. I also have a Turbo XS UTEC. I have yet to put these items onto the car. I need to know if I need to get the resistors for the EGT sensors? Thanks for any help you can offer.
Ninjaboy
Old 08-13-2003, 06:47 PM   #5
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
You will need a resistor for the uppipe. You will also need the resistor/capacitor fix for the exhaust. Search for MIL ELIMINATOR or Pony Express and you will find it. Uppipe resistor is $2 for 6 at Radio Shack. The other fix is around $20. ScoobySport makes an electronic fix similar to the MIL ELIMINATOR for $70 and it is supposed to be "better".
WTB: WRX Wagon Roof Rack, EGT sensor for Up-Pipe, Stock Vacuum Lines w/ pill for TD04 mcmanalot SWIC Private Classifieds 2 04-25-2010 07:28 PM
WTB: Up Stream o2 sensor for a 2002 wrx MT mhwrx02 Private 'Wanted' Classifieds 0 03-31-2010 05:06 PM
A/F O2 sensor in up-pipe or stock - Results 2000vfr800 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-31-2002 02:41 PM
O2 Sensor In Up-pipe Melted...???? dug-e-fresh Normally Aspirated with bolt-on Forced Induction Powertrain 6 02-21-2002 03:38 AM
NAPA O2 Sensor In Up-pipe Melted!...??? dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-20-2002 03:44 PM
