#1 |
Subtly Outspoken
Moderator Member#: 238
Vehicle:99 Ver6 Recreation JDM Speedwagon 3 LSDs..:) |
Well...its time to put or shut up..
...so the RS motor is now OUT of the car....not to bad...about 1.5 hours and she was all clear.....so tomorrow nite...the new front cross member goes in..along with the WRX front sway bar....wahooooooooooooo....I also came upon a new (to me) exhuast system...a BPM GT Turbo back...so the mid pipe and the muffler are already on...wahooooooooo......had to remove the heat shield by the center drive to ensure it wasn't going to rub... anyways...heres some pics... unbolting everything to get ready to pull the motor.... Here you disconnect the everything thats tied to the motor....unbolt the tranny...Drain all the fluids....hoses and gas lines from the motor....don't forget the pitch stop . .... ![]() ![]() ![]()
#2 |
Subtly Outspoken
#3 |
Subtly Outspoken
So as you can see from the pics...not a bad day...
...The clutch was about 2/3's gone...the Flywheel had some hot spots..but no biggie...The flywheel goes to the machinest tomorrow...and he takes 10 lbs off it.... ..the exhuast for the most part bolted right up...I will be using my stock RS Air Conditioner compressor....so it will bolt right back up... The crossmember swap is planned for tomorrow....along with a WRX front Sway bar...... More to come Later... Bill ![]() |
#4 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
eee.. you sure that you want to super heat the univeral joints on the drive shaft?
i had to cut a new hole in my heat shield but i put it back on |
#5 |
Subtly Outspoken
yeah..not sure what I am going to do there...have to see..
Thanks Jaxx...you have a pic of your heatsheild with the mod done??? Thanks Bill |
#6 |
Member#: 11063
Vehicle:2001 Impreza 2.5 RS and bye bye Turtle :( |
Scooby South, You have a PM sir,
Jiffy ![]() |
#7 |
Subtly Outspoken
Well no pics today...but I secured my motor....
...supposedly it only has 1100 miles on it....I saw it...Felt it....smelled it... ...Car was in a roll over....I phsically checked everything....the Good news is ....It gets delivered on Thursday.... .. ....The Bad news is...I won't get to put the motor in till next week...I am going to tow the car home to clean the engine compartment...and take off some of the RS Brackets...The RS Cruise control....Change out the booster and master cylnder..and take out the RS harness.....(The shop is going to be closed...Fri/sat due to paving and painting...)...so at least I can start some of the more tedius stuff... I put my legacy Turbo Crossmember in tonight...NO PROBLEM what so ever....took about 1 hour....Really easy when you have a lift.... ....so the motor is READY to drop in...just have to do some minor maintenance to the engine compartment... ....WRX front Sway bar bolted right up....no problem...lets see...any issues- ....did not drop the control arms to swap it out....unbolted the jackweight in the middle of the stocker...unbolted the steering rack....Mark on the steering knuckle with paint to match up the splines...unbolt the crossmember....take the ball joints loose and work the crossmember out...no biggie...Reverse the procedure for installation...I am now the READY for TURBO... ...Really pretty easy...I will take pictures of the installed crossmember tomorrow... The Stock RS control arms BOLTED right up with no modification to the legacy crossmember...I am really happy about that...no shims...no hassle...and no worries.....Being brand new...I don't have to worry about it being tweeked.....I DEFINATELY reccomend a Turbo LEGACY crossmember...perferably new...that way there is no issues at all with fitment.... Well like I said earlier...I stopped by the wrecking yard to point out to owner what parts I needed...Heres a list of what I am getting from the bone yard..:
thats about it for tonight.. Bill |
#8 |
Subtly Outspoken
Ok...small update..with some Big progress...
Got all the RS wiring labeled yesterday...takes about 7 hours to to lable the ECU and the Bulkhead plugs...including the Engine plugs... Got my WRX fuel pump in... Legacy Turbo Crossmember in..... WRX Brake Booster and Master cylinder in........ some random pics for ya.. Old RS motor getting ready to go Bye Bye... ![]() Same thing as STIMPY....HARNESS time... ![]() ![]() My motor is here.... ![]() ![]() ![]() ![]() |
#9 |
Subtly Outspoken
Engine is from a 02....not sure on milage...looks more than what the Import Auto salvage saids....they say 1100...It looks more like 20000....but it all tested good....so...we'll see....
More pictures... Legacy Crossmember installed... RS Harness Labled....including Bulkhead ![]() ![]() Old RS master Cylinder and Booster ![]() New WRX Booster and MC installed... and last but not least....SOME GOODIES waiting to be installed... ![]() ![]() |
#10 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
Looks like you are having fun
![]() -Jon |
#11 | |
Member#: 177
NWIC
and its kinda ugly i had to do it 4 times befor i got it right .. needless to say the hole is waay to big .. ![]() the metal is very thin i used a wood hole saw to cut the first hole |
#12 |
Homicidal Maniac
Vehicle:2008 STI |
Yes, the metal is very thin. I sliced my thumb to the bone on that damn thing about 2 years ago.
Am I going to have to clearance mine as well? -Jon |
#13 |
Member#: 177
NWIC
all you have to cut a hole for the o2 sensor .. the pipe fits..
hmm well now that i think about it my hks DP (with no cats)fits.. |
#14 |
Member#: 3461
South East
Vehicle:1998 BMW M3 Coupe Estoril Bleau |
can you still order this part at the subaru dealership? If so, please let me know a part number.
thanks, kevin |
#15 |
Member#: 33782
Vehicle:96 bastard child search FIRST, then PM!!! |
hey that is a familiar looking seen. I finished my swap a week ago tomorrow. It's worth it!!
well latinskllz just to let you know you can still buy the legacy crossmember on Subaruparts.com but I've been told the WRX wagon crossmember bolts up perfectly but i found out to late and had to use the regular WRX one and uses washers to fill in the space for the control arm. Hope this helps, Micah |
#16 | |
Member#: 3461
South East
Thanks bro! |
#17 |
Homicidal Maniac
Vehicle:2008 STI |
WRX wagon and WRX sedan both have the same part number for the crossmember. Washers will be needed for any WRX crossmember.
-Jon |
#18 |
Member#: 33782
hmm...
I was told that the Wagon and Sedan had different front crossmembers but that didn't seem to make much sense to me. sorry if I was wrong.Take it easy, Micah |
#19 | |
Subtly Outspoken
![]() Bill |
#20 |
Member#: 24956
Vehicle:1997 Impreza WRX Steel Blue Mica |
i think you might be a little mixed up with something else. i think you're thinking of the WRX crossmember with the WRX wagon control arms. that is supposed to bolt up fine.
Brent |
#21 |
Member#: 14909
BAIC
Scooby South - Don't forget your fuel pump controller and harness. Wasn't in your shopping list so I thought I would just remind ya... it's an important guy to have. It's located in the back passenger side quarter panel near the fuel door... you can reach it through a hole in the side of the trunk... it's a small metal box and you can actually put it up under the dash after you've wired it in... but you should definitely use it...
#22 |
Member#: 2692
SCIC
Are you labeling the wires at the ecu and engine side, and just swapping the plugs to WRX ecu and Engine side plugs? (obviously with some changes, fuel controller, boost control etc etc)?
#23 | |
Subtly Outspoken
Basically..you end up with a seperate engine harness...that is tied into the RS harness at the ECU...so I am using all my existing RS stuff...Speed sensors, tach, AC control, etc....The WRX harness is pretty complete....all the sensors, boost solinoid...,EGT, Front and rear 02's are already apart of the WRX harness...so without have to hack that out....made a big difference...I will have specific information when its all done...to kinda give people a idea of what goes where... Bill |
#24 |
Member#: 4520
Vehicle:93 STi V.4 RA www.flat4lv.com |
I like what you did with the hood prop rod for more clearance!
#25 | |
Member#: 14909
BAIC
| Thread Tools | |
| Display Modes | |
| Ultimate Evo and Impreza ready for battle | AVANTI R5 | Non-Subaru News & Rumors | 19 | 05-04-2008 01:10 AM |
| Ready for battle...DIY lip on a V-limted replica | Scooby South | Member's Car Gallery | 26 | 06-13-2007 04:24 PM |
| Look! - These dorks are ready for battle, so don't mess with them. | snvin | Off-Topic | 85 | 05-10-2005 05:33 PM |
| ready for battle | Blindeye_03 | South East Region Forum | 13 | 10-07-2003 08:51 PM |
| Getting Ready for Battle DAY 1 | Scooby South | South East Region Forum | 33 | 08-19-2003 11:51 AM |
