Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 08-12-2003, 04:40 AM   #1
outferno
Member#: 27469
2004 Forester XT
Question STi 3rd Gear
I was wondering if anybody else with an STi had strange things going on with 3rd Gear. It seems I have to push my clutch all the way down for it to go in smoothly. I shift around 2.5K to 3K RPM from second gear to 3rd and I often find myself having to shove the clutch all the way down for it to not feel like it's grinding. A couple times I pushed the clutch in (with about 1 or 2 inches left before it catches) going to 3rd and it felt like it was going to grind. Is this normal for any of you? Just curious, don't know if I should take it in =/
Signed,
Outferno
outferno is offline
Old 08-12-2003, 06:02 AM   #2
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
Mine does the same thing. It just depends on how I shift. Practice, practice...
dsmperformance is offline
Old 08-12-2003, 08:35 AM   #3
robmarch
Member#: 18713
06 CRV
04 STi
If I remember right, 1st and 2nd have more synchros than 3rd. It might just feel different shifting to 3rd because of having less synchros to smooth out the shift.
robmarch is offline
Old 08-12-2003, 08:58 AM   #4
JLMarx
Member#: 11853
2004 WRX STi
World Rally Blue
You should be pushing the clutch all the way down to the floor with every shift, though. At least, that's how I was taught and works best/smoothest for me.
JLMarx is offline
Old 08-12-2003, 10:27 AM   #5
robmarch
Member#: 18713
06 CRV
04 STi
you use the clutch?
j/k
robmarch is offline
Old 08-12-2003, 11:56 AM   #6
spool1536
Member#: 39724
04 WRX STI
I strongly agree.
spool1536 is offline
Old 08-12-2003, 12:02 PM   #7
robmarch
Member#: 18713
06 CRV
04 STi
what would be the possible advantage of not pushing the clutch to the floor all of the way?
I must be a stick noob.
robmarch is offline
Old 08-12-2003, 12:37 PM   #8
Austin
Member#: 7089
2016 STi
1st and 3rd have double cone synchros, 2nd has a triple cone synchro.
Austin is offline
Old 08-12-2003, 12:55 PM   #9
SubaruBen
Member#: 20948
04 STi
Snow Plower
It goes in like butter for me, I'm shifting at 2.5-3k aswell.
it does take a little time to get use to the short shifter. you will be fine.
SubaruBen is offline
Old 08-12-2003, 01:14 PM   #10
filbert
Member#: 39661
2004 WRB WRX STi
2015 Impreza 2.0
some cars that have an extremely high clutch, the last 2-3" that you push in all the way do absolutely nothing. so by pushing the clutch only half way, you can reduce the movement of your foot and potentially save time during shifts... but it depends entirely on where the clutch (dis)engagement points are on the car.
filbert is offline
Old 08-12-2003, 01:24 PM   #11
Ringboy
Member#: 40693
2004 WRX STi
I experience this from 1-2. Just takes a little adjust on how you shift though.
Ringboy is offline
Old 08-12-2003, 05:38 PM   #12
Monsito
Member#: 40581
04 STi
I noticed the same thing in fourth. The cure for me is to shift faster. It only happens if I get lazy and shift real slow.
Monsito is offline
Old 08-13-2003, 04:19 AM   #13
outferno
Member#: 27469
2004 Forester XT
Ah, all good. I talked to one of the STi owners today while I was at Union City Krispy Kreme and he said his 3rd gear did that too. I guess you guys are right and I have nothing to worry about!!
Signed,
Outferno
outferno is offline
Old 08-13-2003, 06:23 AM   #14
WRX_Mundi
Member#: 33270
2004 STi
WR Blue
I haven't had any issues with mine other than finding 4th can be difficult from 5th (sometimes goes into 6th instead). Getting better at that though.
In my old car I got to the point where I would really know the clutch point, and go down just beyond it, shift, then let up. Now that car (a Miata) had a really short shift -- the STi is way longer, and the revs don't drop as fast either, so upshifts in the Miata were much faster. I'm gradually learning the clutch point on the STi, so I'm going down a little less, but still farther than necessary. Personally I think there is an advantage to not always putting the clutch all the way in. It doesn't really hurt to push it all the way down, but it is extrenuous movement (as long as you really go down far enough to completely disengage it, do your shift, then let it out after your revs are matched).
I experimented in the Miata with clutchless shifting. Interesting, but not a wise idea for longevity. It's all about rev matching really well and not forcing anything. I never did it at race speeds though, and the Miata has a blistering 128hp at the crank which means a lot less load on the system.
WRX_Mundi is offline
Old 08-13-2003, 11:19 AM   #15
SportyBry
Visiting NASIOC Timeout
Member#: 40648
2004 STi
Blue, of course
Shifting at 2.5K-3,000 RPM ? man, that's more of an idling speed !
Basically the less clutching you do the more work the synchros do if you don't match revs. That means tranny wear. Keep up what you're doing for 60,000 miles and you'll be more likely to need a tranny rebuild than the rest of us.
Just learn to clutch faster and jam it right to the floor. If you shift at higher RPMs it also works much, much better.
....Brian
SportyBry is offline
Old 08-13-2003, 04:03 PM   #16
filbert
Member#: 39661
2004 WRB WRX STi
2015 Impreza 2.0
I thought synchros are only used when you're pushing the gear selector into gear? That would mean that your synchros have nothing to do with your clutch work (unless you're double clutching).
filbert is offline
Old 08-15-2003, 01:51 AM   #17
sti-dreamer
Member#: 41400
is there a way to change the clutch disengagement point?? just curious....
sti-dreamer is offline
Old 08-15-2003, 02:08 AM   #18
2003 sedan
Member#: 24103
Post
No. Its Hydraulic.
2003 sedan is offline
Old 08-15-2003, 07:55 AM   #19
robmarch
Member#: 18713
06 CRV
04 STi
if the clutch isn't fully disengaged, the synchros have to work harder, since there is extra movement in the system. These aren't the right words here, maybe someone else can jump in and explain better.
Sometimes this can actually work to your advantage, if your synchros are worn a certain way, from what I've seen. I'd agree that it's better to push to the floor and prevent the extra wear on the synchros in the first place, though.
robmarch is offline
Old 08-19-2003, 12:07 AM   #20
fastwrx
Member#: 7398
2004 2004 WRX-STi
I also noticed a definite "snick" when going from 2nd to 3rd when I first got my STi. It wasn't a grind, but a "snick." That's the best way I can describe it. A slight resistance... like a click-stop. However, nowadays I don't notice it anymore. Probably got better at shifting with practice.
Mike
fastwrx is offline
Old 08-19-2003, 12:21 AM   #21
RichQY
Member#: 31948
2004 STi
my 3rd is kinda like that too
i once mishifted to 5th from 2nd. i knew it was 5th so i took it back to neutral and tried to find 3rd.
was very notchy.. then it grabbed hard.
but that was first 100 miles or so..
a lot smoother to shift now.
RichQY is offline
Replaced 3rd gear synchro Now broken 3rd gear? foxracr10 Transmission (AT/MT) & Driveline 14 02-17-2009 01:00 PM
07 STI 3rd gear 'scratch' into 4th capnchunk Transmission (AT/MT) & Driveline 4 04-22-2008 08:32 PM
05 STi 3rd gear is thrashy dobie0791 Transmission (AT/MT) & Driveline 1 06-13-2007 12:05 AM
2007 sti 3rd gear problem g3ninfinite Transmission (AT/MT) & Driveline 0 05-01-2007 10:07 PM
MY02 STi 3rd Gear Acceleration Testing fatcatwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-27-2003 09:25 AM
