Old 08-12-2003, 01:20 PM   #1
WRXinFL
Member#: 28127
02 WRX
Default utec closed loop worth the effort?
just installed turboxs stg 4 and im supprised that the vf30 doesnt come up to full boost until 3800-4000rpm. im using the stg 4 base map and i was thinking of writing a program for closed loop boost to use the boost gain feature. is it worth the time involved to do so, and does the boost gain help with spool up?
WRXinFL is offline   Reply With Quote
Old 08-13-2003, 08:16 AM   #2
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
I definitely was not happy with how boost was when I tried using open-loop boost control on my Stage 4+TMIC setup. I never had lag THAT bad (full boost until 3800+ rpm), but boost was erratic, and changed day to day.
I changed to closed loop mode, and it's much more consistant. Is it perfect? No. But it's 10X more consistant than open-loop EVER was.
I have my gain set at 47 right now. I tried setting it as low as 45, but it didn't seem to help spool up. I never tried to go lower though (maybe I will give it a shot).
I definitely think full boost should be a lot sooner than 3800, I would guess I can get full boost at least 500 rpm sooner than that.
Kev
Force[FED] is offline   Reply With Quote
Old 08-13-2003, 10:09 AM   #3
TexRex2002
Member#: 36303
06 Evo IX
Default Re: utec closed loop worth the effort?
Writing a program? you mean enter a closed loop map?
Closed loop is very nice. I was able to get far more consistent boost than in open loop. It took like 10 minutes max.
BTW, I am running my boost gain at 42. I get a nice little spike to 17 lbs (stock turbo), and then the boost settles down to 15.5-16 lbs.
TexRex2002 is offline   Reply With Quote
Old 08-13-2003, 10:36 AM   #4
k_thaosta
Member#: 20583
Wow!!.. running stage 4 huh??.. I'm half way there.. if i were at stage 4, i'd try and run at least 19psi closed loop and have max boost by 3300-3500.. you'll never learn if you never try editing your own map... especially having sti injectors and a higher flowing fuel pump.. me at stage 2, stock turbo spools at about 1700-1900 rpm.. hitting max boost by 2500 rpm all the way to redline.. i like it, but no more highend power.. i'll have to wait for that 20g or sr50 upgrade..
k_thaosta is offline   Reply With Quote
UTEC Closed loop boost accuracy DocDetroit Engine Management & Tuning 38 04-22-2003 12:37 PM
UTEC closed loop boost gain setting mick_the_ginge Engine Management & Tuning 6 03-19-2003 09:47 AM
utec closed loop... WRX Jim Engine Management & Tuning 1 03-18-2003 06:01 PM
UTEC Open to closed loop, whats the big deal? Davenow Engine Management & Tuning 22 02-26-2003 03:52 PM
UTEC Closed Loop Boost Maps peterex Engine Management & Tuning 45 01-16-2003 12:07 AM
