Old 08-12-2003, 03:04 PM   #1
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Default No Coolant?
The other day I was taking my radiator fans out of my car when I spilled some coolant by accidentaly detaching the hose leading into the radiator. I probably only spilled 1 cup of coolant and my coolant tank was only slightly below the fill line after running my car for a few hours. I just opened up my hood and I have barely any coolant left. My car hasn't been running hot, but I know I need to add some more. Can I just top it off? What kind of coolant should I use?
whtlegacy is offline   Reply With Quote
Old 08-12-2003, 06:56 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
you can stop by your dealer and pick up some subaru coolant, or just get some prestone or texaco...GREEN coolant and top it off, its not pre mixed make sure you mix it with water 50/50
Jay
Old 08-16-2003, 05:05 PM   #3
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Just a note -- you should use distilled or deionized water when mixing coolant.
vrg3 is offline   Reply With Quote
moving car with no coolant 98tredsvt Newbies & FAQs 17 11-05-2009 03:38 PM
no coolant thermostat? WTF?! fl4tsc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-30-2008 03:53 PM
Can I power car on with no coolant ? Bad Noodle Newbies & FAQs 4 04-26-2008 02:25 PM
Overheating....No Coolant Flowing Through Radiator wrx110487 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-28-2008 12:51 AM
VF30, no coolant lines? HighTechRedneck Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-11-2004 04:36 PM
