Old 08-12-2003, 03:22 PM   #1
blindclown
Member#: 18955
2005 Impreza WRX STi
Question Vishnu Tunning Question
Currently , I'm running a Stage 0 vishnu setup. I bought all the parts that make up to a stage 2 vishnu setup. I just sent the chip(unichip) to get re-programmed by vishnu for the stage 2 setup. I guess I planned on putting the Turbo, Fuel Injectors, and the Fuel Pump in at the same time...basically when I go the chip back from Vishnu. My question is this:
Once I get the chip installed and all mentioned above (turbo, Fuel injectors, and pump), does my car then need to be tuned accordingly or does the chip handle the fuel management from there?
I guess I'm concerned about the fuel, and whether or not the chip will handle the new sti injectors, and fuel pump....if I will need to get this professionally tuned...etc.
Please help...any suggestions?
blindclown is offline   Reply With Quote
Old 08-12-2003, 04:25 PM   #2
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
you do have a turbo back and uppipe right?
ok,just making sure...
if you have all the *same* parts as the vishnu stage 2, you should be okay. the unichip will come back tuned for the stage 2, so it will assume you have the injectors, turbo ,etc in already.
don't put the unichip in w/o the other parts in first.
don't put the turbo and all the other stuff in w/o the unichip
*same = about the same parts, if you have a perrin uppipe, it doesn't matter. if you got a pe 1820 then you might have a problem. *
MikeWRX-NJ is offline   Reply With Quote
Old 08-12-2003, 05:07 PM   #3
blindclown
Member#: 18955
Yeah, I definately have the same parts. All the Necessary parts to make up the Stage 2 package. Thanks.
Old 08-12-2003, 05:11 PM   #4
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
You will be fine.
Need4Boost is offline   Reply With Quote
tunning question and few other questions risnerry Newbies & FAQs 2 01-18-2010 11:14 PM
Have a few general tunning questions...please leave your feedback GregBolby Engine Management & Tuning 3 02-14-2005 07:22 PM
JDM Projectors(hid), header, STi V5 seats, Tommy Kaira, Vishnu Tunned ECUTEK MissWRX Tri-State Area Forum 3 01-05-2004 10:48 AM
VF30 tunning question. scottm1978 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-10-2002 08:01 PM
Vishnu Stage 1 Initial Impressions (TXS stealt/Vishnu map)+ questions [email protected] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 10-31-2002 12:53 AM
