Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 08-12-2003, 06:52 PM   #1
tora
Member#: 5851
09 Forester XT
+ NA Miata
Default Available pads for Brembos
Someone said this was covered but I am unable to uncover the thread. (Maybe because I'm a 'tard and am using the wrong words or wrong spellings)...in any case..I am wondering what brake pads are available as options to fit the Brembos. Any good recommendations for solid street/mild competition pads?
I have checked Ferodo, Porterfield etc but am unable to locate a sure fitment. Any help appreciated.
tora is offline
Old 08-12-2003, 08:41 PM   #2
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Ask for the Porterfield "R4S" (The 'S' is for street vs. pure race) pad in the following designs:
Fronts: FMSI# 781
Rears: FMSI# 109
Get them milled to 14mm thick if you want to use your stock shims. 15mm aught to work without the shims.
Enjoy,
Russ
rlavalle is offline
Old 08-12-2003, 09:04 PM   #3
somebody else
Member#: 21618
Thumbs up
I have been using Porterfields on my WRX with the JDM 4-piston calipers and I have been very happy with them. They stop great, they don't make TOO much dust, and don't heat soak too fast (like some GREEN pads I tried .)
After they get to be about 1/2 worn, they can start to heat soak and glaze and squeal. I just put in new pads (the same ones) this morning before work after 18,000 miles.
But... question... stock STi/Brembo pads not good enough????
--scott
somebody else is offline
Old 08-12-2003, 09:47 PM   #4
Tuning Factory Inc.
Vendor
Member#: 3600
I keep a set of Endless CC-X pads in stock at all times.
Tuning Factory Inc. is offline
Old 08-12-2003, 09:53 PM   #5
PhastM3
Member#: 41181
2004 STI
the stock pads work well,but they are way too dusty for a street car that one wants to keep clean
PhastM3 is offline
Old 08-12-2003, 10:09 PM   #6
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
I believe Carbotech has started making pads for the STi fitment. Best pads you can buy, hands down.
www.carbotecheng.com or PM carbotechMatt on the board.
elgorey is offline
Old 08-13-2003, 12:54 AM   #7
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Tora
The answer to you question is on page 2. Read thru the whole post for lots of info.
http://www.mrtrally.com.au/forums/topic.asp?TOPIC_ID=36
One of my track days. DCCD works great. I noticed a change in handling with every position.
http://jidoshaphoto.com/BeyondTrackD..._105_0581.html
Wombat North is offline
Old 08-13-2003, 12:58 AM   #8
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
At the risk of starting yet another Pad War...
Carbotech's are great... but the racers I know swear by Performance Friction.
When I used StopTechs on my WRX, I used Carbotech Panther Pluses... They didn't fade on the track, but had a disconcerting variation in bite during the same stop. Coming off the straight, they'd initially grab fine... then, as I slowed, they'd grab harder & harder. Finally, when I was slowed and started releasing the brake, they held longer than expected.
However, I'm going to try them again on the STi Brembos. But again, from what I hear from my racing buddies, Performance Friction is the pad to use. They're more expensive, but when you want the very best, you have to pay a little more.
I'll be trying these myself in a few months.
Russ
rlavalle is offline
HAWK DTC-70 Track pads for Brembos Spec C dreamin Suspension/Brakes/Handling 3 05-31-2008 05:14 PM
Front brake pads for brembo grand turismo notraceready Brakes, Steering & Suspension 4 10-07-2007 07:39 AM
FS: Stillen Brake Pads for Brembo Calipers GDB Ben Private 'For Sale' Classifieds 4 05-21-2006 03:14 AM
FS: Stillen Brake Pads for Brembo Calipers GDB Ben NWIC Private Classifieds 0 05-19-2006 02:39 PM
Pads for Brembo 4pot? Alfa Brakes, Steering & Suspension 2 11-16-2004 06:32 PM
