08-12-2003, 09:25 PM | #1 |
Member#: 20852
Vehicle:1995 Impreza L Red |
Help engine swap wiring problems.
I am doing a swap from a 95 1.8 impreza and I am putting in a 93 2.2turbo. I have the full front wiring harness. It just seems that there is not enough wir to run the ecu from the passenger side and hang the main fuse box on the drivers side wall. There is also a pass through of some sort that we can not figure out what it is for. Any help would be appreciated.
James
08-12-2003, 09:27 PM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
You might find more help if you post in the Subaru Conversions forum.
08-13-2003, 07:48 PM | #3 |
Member#: 10642
Vehicle:95 Impreza EJ22T |
The reason there isnt enough wire is b/c the ecu is mounted on the drivers side of the dash on early 90's subarus. Im not sure when they made the switch to pass. side. You'll just have to improvise; on my car I tied the ecu to the instrument panel support beam and modified the lower cover so it would still fit. Where is the 'pass through' you are speaking of?
-Jim |
Phase 1 EJ22 swap wiring problem | Numbchux | Subaru Conversions | 8 | 12-14-2006 11:04 PM |
engine swap wiring... | MrSaabaru | Normally Aspirated with bolt-on Forced Induction Powertrain | 3 | 06-03-2005 02:10 PM |
Engine Swap Wiring | TurmultTee | Subaru Conversions | 4 | 03-27-2005 08:59 PM |
help engine swap problems | james_gt | Subaru Conversions | 5 | 08-13-2003 07:51 PM |
Engine swap wiring question | Impreza Rider | Normally Aspirated with bolt-on Forced Induction Powertrain | 5 | 10-15-2002 07:30 PM |
