Old 08-12-2003, 11:02 PM   #1
james_gt
Member#: 20852
1995 Impreza L
Red
Default help engine swap problems
I am doing a swap from a 95 1.8 impreza and I am putting in a 93 2.2turbo. I have the full front wiring harness. It just seems that there is not enough wir to run the ecu from the passenger side and hang the main fuse box on the drivers side wall. There is also a pass through of some sort that we can not figure out what it is for. Any help would be appreciated.
James
james_gt is offline   Reply With Quote
Old 08-13-2003, 04:01 AM   #2
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
If you're swapping in a JDM engine & ECU, you'll probably need to lengthen some wires, as the ECU's from japan are on the other side of the car (rhd, passenger side is on the left)...
-s-
scotty305 is offline   Reply With Quote
Old 08-13-2003, 05:59 AM   #3
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
2.2 legacy? explain a little more please and I will hapily help you
AWJunkies is offline   Reply With Quote
Old 08-13-2003, 10:19 AM   #4
james_gt
Member#: 20852
1995 Impreza L
Red
yeah sorry about that. Then engine is not jdm and it is from a 93 turbo legacy.
James
Old 08-13-2003, 05:30 PM   #5
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
Have you looked at the wiring in a Legacy Turbo? Try to just do yours similar to the way it was from the factory.
Things might not fit perfectly though, due to the difference in chassis, firewall, etc..
I know my friend is installing an SR20 in his 240sx, and the front clip from Japan had wires running down the left side, while it runs on the right side on his USDM chassis.
good luck,
-scott-
PS, have you looked at the service manuals? You can download them from http://techinfo.subaru.com , a 3-day subscription (infinite downloads) is $19.95
Old 08-13-2003, 07:51 PM   #6
imposter
Member#: 10642
95 Impreza EJ22T
james_gt: Check your other thread in the electrical forum.
-Jim
imposter is offline   Reply With Quote
help... engine swap in my 2002 wrx jmodica Subaru Conversions 2 08-26-2008 11:36 PM
need help with swap problem! spoonfedb18a1 Subaru Conversions 4 10-11-2005 09:33 AM
2000-2004 Legacy engine swap problem turbodiesel Subaru Conversions 6 04-21-2005 12:33 PM
engine swap problem help!!! taeyax82 Subaru Conversions 10 01-02-2005 11:36 AM
Help engine swap wiring problems. james_gt Electrical & Lighting 2 08-13-2003 07:48 PM
