Old 08-13-2003, 12:06 AM   #1
AzNStiImpreza
Member#: 17181
2013 Scion FRS
Whiteout
Default Lightened Flywheel + Lightwieght pulley = problem?!?
Hello all. I own a 2000 subaru impreza 2.5rs and was thinking about purchasing a lightened flywheel for my car. i thought Fidanaza was a good idea becuz it weighs about 9lbs and is the cheapest i can find. One mod I already have on my car is Unorthodox racing pulleys. I've read somethings on NASIOC and RS25 that lightened flywheels and pulleys dont go well because of idling, bogging, and stalling issues etc. etc.
I would like more information on this.
Maybe i can still get a lightened flywheel if i get a "heavier" one like the 14 lbs exedy flywheel?
please help.
AzNStiImpreza is offline   Reply With Quote
Old 08-13-2003, 12:39 AM   #2
Pat L.I.
Member#: 20498
2006 WRX TR
i am currently running gfb pulleys (alternator / crank) and an exedy lw flywheel with exedy sport clutch on my 02 rs. i have no problems. Yes the car is slightly different to drive, more noticeable when the ac is on the revs will drop quicker. but not as bad as i had imagined from reading around the site. basically i just cant be really lazy with shifts, other than that it is fine. took me a few starts to get totally used to it but i love it. definately worth the increased acceleration. im not sure how a 9 lb flywheel will change things though.
good luck
Pat
Pat L.I. is offline   Reply With Quote
Old 08-13-2003, 04:51 AM   #3
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
I've got an Exedy 13lb flywheel, Unorthodox underdrive pulley, not problems.
-s-
scotty305 is offline   Reply With Quote
Old 08-13-2003, 10:15 AM   #4
goobie
Member#: 8273
2006 WRX Wagon
Default 3rd Confirmation
I also have a LW flywheel (15lbs) and the Unorthodox LW UD pulley. No problems.
Chad
goobie is offline   Reply With Quote
Old 08-13-2003, 10:23 AM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
It may cause you to have unsteady idle and possibly stalling if the unsteadyness is drastic enough. Ours idles as if it's lobing over with a big fat cam, but it's just the lowered inertia showing itself. We plan to raise the idle by about 50-100RPM to see if that smooths things out. YMMV.
Don't believe the hype! I wouldn't trade our Fidanza or pulleys for ANYTHING!
Jay Storm
www.sourcemotorsports.com
Old 08-13-2003, 01:29 PM   #6
jsavage
Member#: 15699
02 wrx
Default Anyone have dimensions on these fly wheels?
I want to lathe my own flywheels...anyone got the dimensions or know where to get em?
jsavage is offline   Reply With Quote
Old 08-13-2003, 03:03 PM   #7
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
um, jsavage, I wouldn't recommend this. Most aftermarket flywheels have holes around the outside edge, to reduce inertia while retaining strength. Find a picture of the Exedy flywheels, you'll see.
But if you were to remove a few mm's in the wrong place....
Well, let me put it this way; have you ever seen a flywheel explode? I haven't , but I've heard stories, and that's plenty for me. The stories made comparison to a hand grenade going off near the drivers' legs.
-s-
Old 08-14-2003, 12:44 AM   #8
obyone
Member#: 16523
this anymore???
A pic of my Exedy 12.9lbs flywheel.
I had this baby install while retaining the stock clutch (60K miles) and it still feels stock. It does rev faster, easier to rev match, accelerates quicker, but it feels stock when idling and when crawling at 10mph. I should've gone lighter. So I guess I'll try lightweight pullies or something.
BTW...there is a pic of an exploded flywheel, floating around OT. I'm too lazy to do a search but it has something to do with some transmission tuner.
obyone is offline   Reply With Quote
Old 08-14-2003, 01:01 AM   #9
AzNStiImpreza
Member#: 17181
2013 Scion FRS
Whiteout
i got some lopey @$$ cams so my car already idles low, with the pulleys also. so im still thinkin about getting the flywheel or not.
Old 08-15-2003, 01:03 PM   #10
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
Lots of good info in this thread I started
http://forums.nasioc.com/forums/show...ht=lightweight
Compressed is offline   Reply With Quote
Old 08-16-2003, 03:59 AM   #11
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
With a really light flywheel, it's pretty hard to tell the difference between a 1 pound pulley and the stock 5 pound pulley. It's worth keeping the dampening of the stock pulley if you are getting a lightened flywheel. If you can't or aren't getting a flywheel, a lightened non-underdrive pulley is probably fine. Mike Shields gives some other good reasons in this article.
BAN SUVS is offline   Reply With Quote
Lightened Crank Pulley vs Lightened Flywheel? Gruppe-S Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 05-09-2007 04:56 PM
Using lightened flywheel and lightened crank pulley... 2005wrbluesti Transmission (AT/MT) & Driveline 4 11-23-2006 09:51 PM
Is lightened flywheel + lightened pulleys Bad combination???? wrxdragger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 12-23-2005 08:09 AM
can you use both a lightened flywheel and pulley? MikalsWRX Newbies & FAQs 13 07-08-2005 05:14 PM
lightened flywheel with with lightened crank pulley atomicapples Transmission (AT/MT) & Driveline 6 01-31-2003 03:12 AM
