Old 08-13-2003, 12:02 AM   #1
soloracer
Member#: 38450
Default What would cause a knocking engine?
I have found a complete 3.3 SVX engine that I can pick up for $300 that runs good but has a light knock. I'm thinking at that price it might be worth tearing down and rebuilding. Anyone guess what could be wrong? What would a rebuild kit cost for this engine and where would I find one? Can you get aftermarket pistons (JE, Pauter, etc.) for this motor?
soloracer is offline   Reply With Quote
Old 08-13-2003, 12:55 AM   #2
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
if it is just slight constant knocking, its prolly warn rod bearings. Easy fix that may or may not fix the prob
el~sharko is offline   Reply With Quote
Old 08-13-2003, 01:49 AM   #3
Akiata
Member#: 297
What octane are you running in it. If you are not run 91,92,93 what ever your state has.
Maybe replace the plugs.
Akiata is offline   Reply With Quote
Old 08-13-2003, 02:53 PM   #4
Austin
Member#: 7089
2016 STi
Are you talking about spark knock (knock/ping under load) or a knocking sound at idle?
Austin is offline   Reply With Quote
Old 08-13-2003, 03:40 PM   #5
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Naturally Aspirated Forum?
-bd
What Would Cause Check Engine Light 06WRXMIKE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 04-26-2009 10:38 PM
What would cause an engine to sieze? tverdek Subaru Conversions 19 12-30-2007 07:54 PM
what would cause gear popping HOK Transmission (AT/MT) & Driveline 8 12-03-2001 06:16 AM
('93-'01) What would cause difficult downshifting? subymamma Impreza Forum 7 08-07-2001 04:36 PM
What would cause the rear wheels to not spin? tmat3 General Forum Archive 1 03-06-2001 07:29 AM
