Old 08-13-2003, 09:53 AM   #1
JOHN16V
Member#: 21491
2000 Subaru Impreza
2.5RS BRP Sedan
Default Quick strut bar question?
Will a 02-03 WRX front strut bar fit a 98-01 RS? What I am trying to said is I found a aftermarket front strut bar for the 02-03 WRX
will it fit without mod.?
Thanx
John
JOHN16V is offline   Reply With Quote
Old 08-13-2003, 11:32 AM   #2
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
no...
DanzBorin is offline   Reply With Quote
Old 08-13-2003, 11:46 AM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
if you want a cheap one, you can get this one. I've got it.....it works fine.
http://www.procarparts.com/store-det...%2DFR25%2DSTBX
Legacy777 is offline   Reply With Quote
Old 08-13-2003, 11:57 AM   #4
JOHN16V
Member#: 21491
2000 Subaru Impreza
2.5RS BRP Sedan
Thanx guys,
Hey Legacy777 you got one for your impreza? Is that a 20mm bar? Look good for that price I can even paint the end pink!!
John
Old 08-13-2003, 12:31 PM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
why dont you just get a whiteline strut tower bar for your car?
they're cheap - http://secure.cartsvr.net/catalogs/c...ut&catid=13029
(ends are now silver on em, no more yellow)
just another option.
Jamie
Old 08-13-2003, 04:21 PM   #6
Legacy777
Member#: 4800
Originally posted by JOHN16V
Thanx guys,
John
I got one for my legacy. The impreza was built off the legacy platform, so up until 99 stuff is relatively interchangable.
I don't know the size of the bar, it's oval in shape, and it's not like sway bars where size determines much. Larger size strut tower bar means heavier and more rigid.
Only issues I had with it was one of the bolts that holds the bar to the bracket got stripped. I think it mainly happened because they chromed the bolts.....the chrome plating can flake off the threads and you get stripped bolts. It happen mid way, so it wasn't because i mis-threaded the bolt. I had to use a dremel to cut the nut in half, but just then went to lowes, bought some good quality bolts, washers, and nylon nuts, and works fine.
A quick plug for Jamie's whiteline bars. I would've got one of those but the rear facing interfered with my hella horns, and I didn't like the front facing.
Josh
Old 08-13-2003, 11:40 PM   #7
obyone
Member#: 16523
$35 is too much. I only paid $10 for mine.
obyone is offline   Reply With Quote
Sway Bars/Strut Bars Questions iceman1733 Brakes, Steering & Suspension 14 08-07-2008 01:19 PM
Rear Sway Bar + Front Strut Bar question..! shum_87 Vancouver Impreza Club Forum -- VIC 3 09-06-2007 02:58 AM
Quick Strut Bar Question Gorge Brakes, Steering & Suspension 4 10-31-2006 04:10 PM
Quick sway bar question Plays_With_toys Legacy Forum 9 03-04-2006 03:00 AM
Quick Strut Top Question boostin04 Brakes, Steering & Suspension 4 08-30-2005 03:21 PM
