Old 04-04-2001, 10:06 AM   #1
ImprezedRS
Member#: 2771
2003 BMW Z4
Question EJ22T swap into RS, tranny question?
I'm thinking about swaping out the EJ25 in my 00 RS with the legacy EJ22T, I will be using the EJ25 heads on the block and wiring harness. But my question is since i have an 4EAT automatic tranny will i have problems with the EJ22T block connecting to the tranny?
ImprezedRS is offline   Reply With Quote
Old 04-04-2001, 10:08 AM   #2
subarurabbit
Member#: 4083
2011 OB 3.6R
Post
it will probably work, but remember that you'll need to check your rear diff ratio.
Roger
subarurabbit is offline   Reply With Quote
Old 04-04-2001, 10:08 AM   #3
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
Nope. 90+ Subarus, excluding the Loyale and Justy of course, are all bolt compatible.
ScoobySlack's EJ22T came from a Legacy Touring Wagon like mine, with a 4EAT, and most EJ22Ts were mated with automatics.
DLC is offline   Reply With Quote
Old 04-04-2001, 10:17 AM   #4
Suba-RAW
Member#: 2831
Question
This isn't the same EJ22T that's in the 22b is it? Or, if not, could it be modded to become the 22b?
Suba-RAW is offline   Reply With Quote
Old 04-04-2001, 10:30 AM   #5
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
The EJ22T shares only the same displacement as the 22b motor.
It does however have a closed deck, and the SOHC and DOHC heads from the EJ25 will basically bolt on without issue.
Byron's B-Spec Impreza has this setup with the SOHC, T3/T4 and well over 500hp, so...
Yes, it could eat a 22b for breakfast.
Old 04-04-2001, 10:47 AM   #6
rpone605
Member#: 1669
2004 WRX Sport Wagon
Post
hey your not far from teagues he's doing a ej22 swap you should go talk to him.
rpone605 is offline   Reply With Quote
Old 04-04-2001, 10:57 AM   #7
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
Yeah i know that i'm close to Dale Teague and hopefully will get to see him in 2 weeks
Old 04-04-2001, 11:43 AM   #8
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Post
Also, if you are going to swap EJ25 heads onto the block, I am pretty sure you have to swap DOHC heads, which you do not have on your RS.
Mebbe not - here is the 2.5 heads on a 2.2 block thread.
[This message has been edited by blaster88 (edited April 04, 2001).]
blaster88 is offline   Reply With Quote
Old 04-04-2001, 07:43 PM   #9
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Post
I did it and now I'm running pretty nicely...
Just a little rich because i put in big injectors... nothing i hope an SAFC won't fix... but with the block connecting to the tranny you will have some problems with the starter. I had some problems with the starter with one bolt. Who is doing this for you... they should be able to fiqure it out though... Wasn't too hard... if there is a problem... pm me...
HOK
HOK is offline   Reply With Quote
Old 04-05-2001, 12:28 AM   #10
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
You can go either way on the heads, DOHC or SOHC, i will be sticking with the SOHC
Old 04-05-2001, 07:28 AM   #11
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
Me and one of my friends will be doing this.
Old 05-16-2002, 11:00 PM   #12
japporeyser
Member#: 18936
1993 Impreza L Sedan
Colgate White
hi guys..i have a 1993 impreza L...i am also trying to swap in a EJ22T....the only thing is I have AUTOMATIC tranny...i know i can swap the legacy turbo engine in there..but my concern is if I can do it and my AUTOMATIC tranny will still work with it...or do I have to get a tranny swap also..please help me..thanks in advance
japporeyser is offline   Reply With Quote
Old 06-05-2002, 01:28 AM   #13
erice1984
Member#: 11778
1980 VWRabbit Diesel
w/AAZ Swap
im ideals for power/reliability. which would be better:
EJ22T hybrid w/EJ25 heads
or
EJ20T from a new age 02 wrx
Thanks
-Eric
erice1984 is offline   Reply With Quote
Old 06-05-2002, 09:14 AM   #14
XT6Wagon
Member#: 524
04 STi
I'd do a 02 EJ-25 shortblock, with 02 WRX heads and manifolds.
XT6Wagon is offline   Reply With Quote
Old 06-05-2002, 09:16 AM   #15
XT6Wagon
Member#: 524
04 STi
I'd do a 02 EJ-25 shortblock with aftermarket rods & pistons, with 02 WRX heads and manifolds.
Need question answered for doing 1993 Ej22t swap into 1998 impreza Mechkiller31st Pre-2002 Factory Turbo Powertrain 31 09-14-2010 05:56 PM
Question for ppl that have done the EJ22T swap into Impreza trowa Pre-2002 Factory Turbo Powertrain 4 10-18-2007 03:02 PM
ej22t swap into 95 leg... ecu? legacy2003 Pre-2002 Factory Turbo Powertrain 6 10-01-2003 07:37 PM
EJ22T Swap into MY99 Soon2BturbodRS Subaru Conversions 10 09-18-2003 02:08 PM
('93-'01) price on an sti engine/tranny swap into RS Krelkor Impreza Forum 4 10-12-2001 01:09 AM
