Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 03-23-2001, 11:11 PM   #1
Rubasu
Member#: 1418
MY00 2.5RS
Post Anti-Lag????
Hey all -- I was wondering what the heck an anti-lag system is and how it works? I am going turbo this summer and waas wondering if there are any benefits on the street/strip to having this thing? And where could i get my hands on one when the time comes?
thanks
Rubasu
Rubasu is offline   Reply With Quote
Old 03-23-2001, 11:21 PM   #2
Shik
Member#: 132
2006 GT Ltd 5spd sdn
2015 WRX 6spd CWP
Post
Don't mean to come off the wrong way, but try a search in this forum. It has been talked about many times. Try anti-lag or ALS, you should find some good stuff.
FWIW, the "bang bang" system, as it's known, is probably one of the coolest things known to man(IMHO), but has no place on a street car, unless you know of a "buy 1 turbo, get 50 free" type deal. Then again, I guess you don't have to use it all the time either.
Although it is odd that more of the import drag cars don't use the system. I mean, I know they are pretty fast shifters, but when you are talking about hundreths of a second and the money they already have into the cars, I would think an ALS would be of some benefit, no?
[This message has been edited by Shik (edited March 23, 2001).]
Shik is offline   Reply With Quote
Old 03-24-2001, 12:21 AM   #3
Buck-O
Guest
Member#:
Post
ALS is an interesting system.
Basically it takes the exaust valve of the engine and retards it, dumping raw fuel into teh exaust manifold, as it hits the hot manifold around the turbo, the fuel ignites, basically turning your exaust manifold into a combustion chamber to keep the turbo spooled and creating boost when the driver lifts. Or to creat boost when the car is at idle. WRC cars make around 6psi of boost at idle. So thats what ALS is in a nut shell.
The draw backs of it are EXTREME heat. The manifold usually needs to be heat treated, and ceramic coated. And your turbo should have a ceramic impeller, and ball bearings. If you dont have all of these, and ALS system will MELT your manifold, and your impeller. Not good.
Its preaty much usless for street use. And for dragracing its completely useless, becuase the time it takes to engage and disengage the system isnt worth it. Right off the line it would work well, but after that it would be preaty damn pointless, and may actually make the engine lag when it adjusts the cams phase.
Unless you have about 10 grand to dump into a complete exaust, and turbo kit...stick with a plain ole turbo kits and leave it at that. Unless your runing stage II turbo or higher, its not worth it.
Unless you know alot about turbo setups, you shouldent even consider it.
Old 03-24-2001, 07:50 AM   #4
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Post
I think its more along the lines of this:
- when you lift off the throttle from acceleration, the ecu retards the timing by a large amount. During this, extra fuel is dumped in the chamber causing backfire moreless. This backfire is what keeps the turbo spooled up and not leaving it to spool down. Hence the system name "anti-lag" . It is not necessarly hard on the manifolds, but it is hard on the turbo lifespan because of the constant high temperatures that the anti-lag produces.
Anti-lag system does not involved adjusting cam-timing, just ignition timing. And it I don't think it makes any boost at idle(unless you are revving it) But I think you are confusing it with launch control system.
Ver.III is offline   Reply With Quote
To Anti-Lift Kit..? Or, Not to Anti-Lift..? PSRS (+Video) krylon General Community 45 11-07-2009 10:10 PM
Since there are anti-smoking and anti-marijuana ads... why no anti-drinking ads? chkltcow Off-Topic 19 03-29-2009 11:43 PM
Snowden - Anti Anti Blknblu Off-Topic 9 04-09-2007 05:05 PM
anti gravity snake, part deux: anti-gravity snake strikes back LatentWagen Off-Topic 14 03-22-2007 10:50 AM
anti foreigner is anti american Caddy Daddy Political Playground 61 02-28-2004 08:44 PM
