Old 08-13-2003, 12:26 PM   #1
jsavage
Member#: 15699
02 wrx
Default Bad Valve Rattle...What's the Cause?
I get loud valve rattle during hard acceleration (hot or cold) on a 96 Impreza...anyone know the main cause? Not consistent either...most days it is fine.
jsavage is offline   Reply With Quote
Old 08-14-2003, 06:48 AM   #2
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
Maybe it needs the valve lash adjusted? Does a '96 even have a valve lash adjustment procedure?
What about bad gas? Have you tried a tank or two of the premium gas?
Just throwing some stuff out there...
spshultz is offline   Reply With Quote
Old 08-14-2003, 10:30 AM   #3
jsavage
Member#: 15699
02 wrx
I dont know....But I have tried good gas.
Old 08-15-2003, 01:40 AM   #4
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
Do you get this noise if you rev the engine while in neutral or park?
Old 08-15-2003, 04:26 AM   #5
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
If you're running a 2.2L it could be hydraulic lifters sticking and causing your noise or it might even be your timing belt tensioner. I'd check out those areas to rule out two of the most common causes of the noise and identify why it's inconsistent. Also, as was mentioned, if you've got ~100K miles on your car, it's probably time to do a valve readjustment.
Could be a batch of bad gas or octane too low during the hot summer season as well. This is the time of year when the humidity and the heat conspire to stress your engine, particularly the heat, which can cause an ECU ignition retard and pingo goes the engineo.
Just a couple of thoughts. Keep us appraised of your isolation progress.
Br, Dale
Subietonic is offline   Reply With Quote
My fan runs as soon as turn the key, what's the cause? Henryk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-30-2009 12:17 PM
What's the part number? Idle Air Control Valve Gasket nicholam Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-29-2008 12:36 PM
P0304 #4 misfire = bad valve. Here's the valve. hikeeba Service & Maintenance 5 11-07-2006 01:34 PM
What's the most serious condition that will cause a constant CEL (non-flashing)? TinyIvan Warranty Issues & SOA Problems 4 08-12-2002 10:33 PM
What's the number for damages caused by potholes and such on the road....? latinskllz South East Region Forum 1 08-02-2002 03:18 PM
