Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 08-13-2003, 06:36 PM   #1
BritSti
Member#: 38057
2010 IS-F
USB
Default Alignment or Memory Steer?
After my thrid alignment in two weeks on an 04 Sti I still have a slightly offcenter steering wheel which changes position depending on what type of corner was just taken, I guess you could classify this as a wandering wheel, the car tracks straight and true..:
hard right corner = steering wheel offcenter to the left.
hard left corner = steering wheel offcenter to the right.
My question is could this be a symptom of a bad wheel bearing, I noted another post on the forum for an 04 Sti which had the wheel bearings replaced at 1200 miles... I've got 2200 miles, dealer seems to think it was just an alignment issue...
Any suggestions would be appreciated....
BritSti is offline
Old 08-13-2003, 06:46 PM   #2
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
Search this forum. Other people had similar issues.
dsmperformance is offline
Old 08-13-2003, 11:40 PM   #3
BritSti
Member#: 38057
2010 IS-F
USB
OK after a little research it looks like I have the dreaded "memory steer" issue which seems to affect 2002+WRX's in decent numbers.
Anyways the issue is described as soft steering bushings which allow the rack to flex, creating the memory effect after a decently hard corner... poly bushings from whitline for $25 are suggested, but look like a pain to install.
Will be talking with dealer service tomorrow, not sure if there is any resolution the dealer can give, its annoying enough it makes me reconsider the car...
BritSti is offline
Old 08-14-2003, 01:44 AM   #4
ch692115
Member#: 11229
2007 WRX STI LTD
satin white pearl
don't reconsider, stick with the car dude, if it tracks straight then that's all that should matter. i get the problem with my sti too. just try and vary your turns. i do have to admit my wrx wagon didn't have this memory steer issue.
ch692115 is offline
Old 08-14-2003, 11:11 AM   #5
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
Here is the thread I was talking about...
http://forums.nasioc.com/forums/show...hreadid=403068
2000 RS Clutch and Wheel bearing issues 3BadHabbits Tri-State Area Forum 8 10-24-2003 07:01 PM
2004 Sti Wheel Bearing Issue? BritSti Warranty Issues & SOA Problems 6 10-01-2003 10:00 AM
Wheel Bearing issues? SOA releases new "procedures" Opie Brakes, Steering & Suspension 1 09-18-2003 02:28 PM
Rear Wheel Bearing Issue minx Normally Aspirated Powertrain 20 05-01-2002 04:24 PM
