08-13-2003, 06:22 PM | #1 |
Member#: 33293
Vehicle:2011 4-door STi Plasma Blue |
Another oil pressure sender question...
I got the sender installed but the screw on top of the sender is getting in the way of my intercooler hose. Did anyone else have this problem with the autometer sender unit. If so How did you solve it. I was thinking moving the unit to the other gallery plug behind the alternator and putting the stock dummy light in the gallery plug under the intercooler. Any other suggestions?
~Danny
08-14-2003, 01:20 PM | #2 |
Member#: 7869
Vehicle:2011 STi TheUrbanRallyProject.com |
what type of autometer gauge did you use. I mean Pro-comp etc... did you have to buy the adapter seperate?
08-17-2003, 11:56 PM | #3 |
Member#: 33979
South East
Vehicle:2006 STi WRB |
There is a lot of space there - you must be using an adapter or autometer has a hella tall sender.
That said there is no reason that the stock pressure switch (you are in trouble well before 2.5 lbs) would not work in the rear gallery and the temp in the front. I know others who have done gauges that way. |
08-18-2003, 02:54 AM | #4 |
Member#: 30798
Vehicle:2001 RS-T Hybrid 2.5>2.2T>257>2.35S |
I had the same problem with mine I ended up getting a stainless line and made up a bracket and attatched it to the fender you could also run it to your firewall and mount it there.
08-19-2003, 06:50 PM | #5 |
Member#: 33293
thats a great suggestion speed freak. I will definitly wind up doing that. Where can I get that stainless line you are talking about with the right size and all?
08-19-2003, 07:05 PM | #6 |
Member#: 33979
South East
Omori remote mounts the oil pressure sender with a standard hose see here:
Omori install. I think but am not positive this is the part number: P-285 teflon mesh hose L type L=500mm with teflon made for racing There is no picture on the site but if you check with them just ask for the hose used with their electric oil meters. |
New Oil Pressure Sender, Wiring Question? | wrxprowler | Electrical & Lighting | 2 | 07-21-2009 04:23 PM |
Prosport Premium Gauges 52mm Oil Pressure and Temp Remote Oil Pressure Sender Kit | skribblez32 | Interior/Dressup/Audio & Security | 4 | 07-01-2009 03:50 PM |
Prosport Oil Pressure Sender Question | crazycanasian | Electrical & Lighting | 8 | 09-19-2008 01:38 PM |
Prosport Oil Pressure Sender Question | crazycanasian | General Community | 2 | 08-19-2008 06:52 AM |
Couple of questions about the stock oil pressure sender... | Impreza Rider | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 06-26-2003 07:43 PM |
