Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 08-13-2003, 11:13 PM   #1
STiLess
Member#: 41748
Default STi has a shorter stroke than the Evo?
Hi i am new here and if I act like a newb, please dont flame me too bad.
Well anyway I was reading the june issue of road and track, and I saw that the STi has a stroke of 79mm compared to the Evo's 88mm. If this information is correct, then could someone please inform me why it would be so difficult for the STi to hold 8000 rpms? I have read a couple of threads that discussed the weakened crank strength of the STi due to the longer stroke of the 2.5L compared to the 2.0L, but at the same time I have herd of ecu reflashes for the Evo to hold 8000 rpms. So why would the STi not be able to do the same as the Evo which has a longer stroke? I am not trying to be arrogant; I just found this new issue to be perplexing.
Of course this information could be wrong, and if it is, could someone please inform me of the correct bore x stroke of the Evo and STi?
STiLess is offline
Old 08-13-2003, 11:26 PM   #2
Mr. Grinch
Member#: 34416
2002 BMW M3
Alpine White
I'll let the STi experts tell you the real reason the 2.5 turbo can't do 8k rpm. Actually it probably can, just not for any extended period of time.
Suffice to say, a lot of variables are involved. It's not enough just being "strong" enough to handle 8K rpm. It also has to be light enough to do the high RPMs without causing severe vibration or damaging recprocating forces. That includes the bottom end AND the valvetrain. So if for example the STi crank, pistons, con rods, could already handle 8K rpm or better, doesn't mean neccessarily that the valvetrain can, or vice versa.
I'm just picking on the valvetrain because very often it is the first thing to let go in an over-rev situation.
Mr. Grinch is offline
Old 08-13-2003, 11:35 PM   #3
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
I'd like to think that I've been paying attention to stuff like this, and I haven't seen anybody try it yet. We don't even have an ecu upgrade yet. I would think it should be able to take it though. Keep in mind the stock turbo would be hopelessly out of breath.
Kevin
Red Rocket is offline
Old 08-13-2003, 11:52 PM   #4
XT6Wagon
Member#: 524
04 STi
The EJ257 shortblock should be able to take 8K till the cows come home. The EJ257 shortblock might even be able to take 9K for long periods of time depending on the bearings, oiling system and rods.
The heads are a different matter. The however should take 8K all day long if they got the normal STi springs instead of some softer ones with our lower rpm limit.
As for why the STi has a 7K limit stock?? Well isn't 1K of puke and die enough for you?????
XT6Wagon is offline
Old 08-14-2003, 12:15 AM   #5
STiLess
Member#: 41748
I specificaly remember that one of the reasons that people are doubting the 257 is that the stroke is longer than the 205 and therefore, more prone to stress. At the same time, it seems illogical to say that the 4g63 will have less crank issues than the 257 because the 4g63 has a longer stroke. I remember there was a very long thread about this issue. Am I just missing a bigger picture?
STiLess is offline
Old 08-14-2003, 12:17 AM   #6
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Yep, we need another 1000 rpm of tapering power where the stock turbo is totally maxed out!
It will do just fine with bigger turbo, the heads+cams are good enough. When Clark ran that AVO450 on the sti at 16 psi, it made peak power at redline. Thus, you would think it would continue making usable power beyond that. It remains to be seen what will happen with more boost though.
Kevin
Old 08-14-2003, 08:57 AM   #7
CincySTI
Member#: 37492
2004 STi
Did you happen to look at the bore dimensions on the STi and EVO? I think the STi has a much larger bore, which means the pistons are bigger (more mass). Higher piston mass will translate into more force on the crank bearings. I don't know if this is the reason there is only a 7K rpm redline, but it may be part of it. At this point, nobody really knows how much the engine can take and what the weak link is.
CincySTI is offline
Old 08-14-2003, 11:42 AM   #8
dbarnblatt
Member#: 7993
1997 SVX LSi
Red
Default Boxer Engine
Also remember that you are comparing the Lancer Evo's in-line 4 to the Impreza's boxer 4.
dbarnblatt is offline
Old 08-14-2003, 11:53 AM   #9
jbrennen
Member#: 37478
2003 Evo
Absolutely right. Not sure about the stock STi engine's limits, but in general it is pretty common to replace camshafts and valve springs when trying to make an engine run high RPMs.
jbrennen is offline
Old 08-14-2003, 12:35 PM   #10
STiLess
Member#: 41748
Default Re: Boxer Engine
I am just curious, why is an inline better (not saying that it is) than a boxer in terms of the ability to rev? I know everyone has herd of skylines making 1000hp with 12k of rpms.
Also the Sti has a signifigantly larger bore than the Evo. 99.5mm compared to 85.0mm. I know ths will also have an effect on the stresses in the Evo and STi, but how much?
STiLess is offline
Old 08-14-2003, 12:52 PM   #11
Austin
Member#: 7089
2016 STi
I missed that - got a link?
Austin is offline
Old 08-14-2003, 01:00 PM   #12
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
I think he was intentionally vauge about it.......
http://forums.nasioc.com/forums/show...ghlight=avo450
http://forums.nasioc.com/forums/show...hreadid=398554
Old 08-14-2003, 01:29 PM   #13
Mr. Grinch
Member#: 34416
2002 BMW M3
Alpine White
Default Re: Re: Boxer Engine
A boxer balances out the piston movements by making them nearly opposite of each other. A 4 cyl inline usually requires a damper / balancer on the crank to reduce vibration, unless something is done to reduce weight of the moving parts (which reduces vibration).
Skylines and Supras are known for high rpm because they are inline 6s, not 4. An I6 has almost perfect balance between the reciprocating weight, there is always a cyl going down opposite the one going up, so there are very limited harmonic vibrations. A V12, which is two I6 in a V, is even better.
Old 08-14-2003, 01:42 PM   #14
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
I would just assume that the point of view from SOA is that there is nothing left from the turbo at after 7k so why make reliability suffer when there is no performance gain. But I am very interested to see what the rev limit is that still maintains reliability with an upgraded turbo.
(Please don't flame me for being a mechanical idiot if I say something way wrong.) Even if it were only 7500rpm, that could make a bit of difference in the 1/4. From what I have read one of the minor complaints of running the STi in the quarter is you really don't get the use of sixth gear. Well, it could be a bit of a juggling act to keep the boost high in the right range and not be caught going from 5th to 6th at the finish line if you keep uping the rev limit and the amount of boost both. But I would think that tuners wouldn't have any problems getting that down.
offset
offset is offline
Old 08-14-2003, 03:30 PM   #15
Austin
Member#: 7089
2016 STi
Thanks
Austin is offline
Old 08-14-2003, 04:35 PM   #16
STiLess
Member#: 41748
Default Re: Re: Re: Boxer Engine
Ah now that makes perfect sence. Thank you for enlightening me.
STiLess is offline
Old 08-14-2003, 04:48 PM   #17
Mr. Grinch
Member#: 34416
2002 BMW M3
Alpine White
I agree with what Red Rocket is saying. The first goal should be to make useable power up to redline. By that I mean, it's still giving more acceleration if you stay in gear to redline than if you were to shift to the next gear. If you've still got useable power beyond that, depending on your gearing, then you might start looking at extending the redline (and at some point upgrading things like the valvetrain depending how far you go).
If the power isn't useable up to redline (the way the car is stock with the exception of first gear) no sense in changing redline.
According to the info posted in another thread, the shift points for gears 2-5 are around 6500 rpm, for max acceleration.
shift points
From another thread here:
STi Top Speed
STi Top speed theoretical at 7k:
(1) 36
(2) 56
(3) 76
(4) 99
(5) 138
(6) 176
As far as shifting into 6th gear in the 1/4 mile, I don't see how that's even possible, on the stock STi. Even if you shift at 6500 I don't see you getting out of 5th gear on a stock STi, considering 5th gear does 138mph at 7k rpm. So that would be about 128mph in 5th gear at 6500 rpm.
Unless you know something I don't, I don't see stock STi doing 128 mph at the end of the 1/4 mile.
For reference, M3 does 138 in 4th gear, you don't even get into 5th in the 1/4 mile, 5th and 6 don't exist for practical purposes. STi does about 99 mph at 7k in 4th. So you'd need some serious mods to bring up the redline AND the useable power to have an STi tuned for 4th gear finishes, or some change to gearing / tire sizes.
But since STi isn't really intended for 1/4 mile why tune it for that? Neither STi or M3 is suited for drag racing. It's better to be out there to have fun, and if you're really into drag racing with a car that is not optimized for it, you'd be focusing instead on bracket racing, which amounts to getting the most consistent times over several races, not all-out speed. This focuses more on your driving and prep skills than on performance boosting mods. These skills will serve you well if even if and when you do move on to real drag cars.
Old 08-14-2003, 06:57 PM   #18
LinuxGuy
Member#: 17270
1998 Fender Bender
Holds 1000lbs.
Didnt you know another 1000RPM will put you in Bonus Honda VTEC mode?
What a noob....
LinuxGuy is offline
Old 08-14-2003, 06:59 PM   #19
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
What a noob....
huh?
Kevin
Old 08-14-2003, 08:46 PM   #20
hatchy
Member#: 36852
2004 STI
At redline, the STI's moving the piston at 60.5 ft/sec vs 67.4ft/sec on the 4g63. If the STI's redline is 8K, then the piston speed is at 69.1ft/sec. With a big bore piston, that is a lot of mass being throw around at a pretty good speed.
The 2.0 STIs have 8K redlines, don't they? I am not sure what the difference is between the US STI head and the non US STI head, but if the valves, springs,valve guides, retainers, and cams are the same, then at least the head is ready...
hatchy is offline
Will the us 07 sti turbo produce more hp than the us 04-06 sti turbo? silver07sti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-28-2007 06:52 AM
STi has a different windsheild than the other WRX's? criz Interior & Exterior Modification 28 02-09-2006 04:39 PM
280WHP Dyno-Dynamics WRX slower than the EVO MR sonicowrx03 Proven Power Bragging 66 12-17-2004 02:24 PM
Does the STI weigh less than the EVO? Triple S STi Forum Archive 7 08-08-2003 03:40 PM
Does the STI hood scoop flow better than the stock WRX scoop?? atf78 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-24-2001 02:06 PM
