#1 |
Visiting NASIOC Timeout
Member#: 40546
I have noticed an unusual phenomenon. I want to see if any other WRX owners have made note of them same, and if so, might any of you know what causes it?
I have noticed that in the morning when I start my car it will start incredibly fast (or any other time when the car hasn't been driven for at least 3 hours and the temperature reading shows to be at the bottom). But if I go do, say an errand or two, and start the car again after having just recently driven it, it will take considerably longer. It's weird. Basically when the engine is totally cold it will start lightning fast. If it is hot it will take 3-4 times as long. Has anyone else noticed this? Does anyone know what causes this?
#2 |
Member#: 36411
Vehicle:I can be PM'd at "mattjk" |
Engine heat soak, and the cold start injection mode being off will cause that. It's a fairly normal phenomenon. Water temp is high, so the computer retards the timing more than when it's cold. Many other factors.
#3 |
Member#: 7089
NWIC
Vehicle:05 Legacy GT Sedan 07 4Runner Limited |
Be sure to turn your key to the ON position for 2-3 seconds before going to the START position to allow the fuel system to prime the rails.
#4 | |
Member#: 5893
E. Canada
Vehicle:1997 Black GC4 1995 White BK6 |
#5 |
Member#: 36411
Wha?
The stock system stays pressurized for quite some time. All EFI fuel systems retain high residual fuel pressures, unless your check valve is leaking. This has been known to happen on WRX's. |
#6 |
Member#: 26933
BAIC
Vehicle:2006 STI CGM |
My WRX does the same thing. On cold start it fires right up but takes a couple cranks when its warm.
-- Ed |
#7 |
Member#: 10334
Vehicle:91 RX7 LSx swap '09 CC 3.6 4motion |
what kind of timing advance is the ecu trying during hot start? during cold start?
#8 | |
Member#: 36411
#9 |
Member#: 10334
Hmmm I was just wondering. trying to setup a link and I am having trouble with starting. (~5 cranks before she fires up) I have messed with cold start enrichment, hot restart enrichment, crank enrichment...etc... but i haven't played with the timing down there. I believe it came preset at about 4-6 degrees over static in those fields. Just wondering if I should advance that or retard that.
#10 |
Member#: 12619
Vehicle:02 WRX Wagon #47 SM w/RA gears |
Hot start is an issue with many sports cars. Some old 911s just flat out won't crank when they are hot. They're also air cooled and "hot" to them is "H-O-T" to us.
#11 |
Member#: 40546
I'm glad others here recognize this...I saw it as an odd phenomenon at first but then maybe realized that it might be due to the fact I have never owned a turbo car before.
#12 | |
Member#: 30342
#13 |
Member#: 40501
Vehicle:2005 Decathalon 21sp One WheelSeanPower |
Like Fliz said, same thing here, but I'll take it a step further. My car ALWAYS starts faster if I turn it to "on" for 2-3 seconds first, then crank it. Cold, hot, whenever. It might take 0-2 cranks cold going straight to "start", or 0-1 cranks if I let it prime first.
It takes 2-3 cranks hot, and still 0-1 if I let it prime first. FWIW... |
#14 |
Member#: 17328
Vehicle:2002 WRX Wagon 4EAT Appliance White |
I have an '02 WRX and suspect the residual check valve is leaking down. Can someone direct me to where it is? A picture would help. The dealer was no help (no surprise). Is it easy to get at and change? Approx cost? THANKS!!
#15 |
Member#: 17328
Bump for information on the location of the residual check valve on an '02 WRX. There has to be one as stated further up on this thread.
Thanks! |
| Thread Tools | |
| Display Modes | |
| GF8 STI block of the engine | Mirone | Car Care & Detailing | 2 | 06-02-2010 08:35 AM |
| If the engine will not start, tighten both of the screws until they resist and stop. | St3fan | Off-Topic | 32 | 03-19-2010 01:49 PM |
| How do you crank the engine over without starting the car? | Fierysun | Factory 2.5L Turbo Powertrain | 3 | 03-19-2009 06:09 AM |
| Irregular sound when starting the engine. PLEASE help. | Verity | Newbies & FAQs | 6 | 01-15-2009 02:29 AM |
