Welcome to the North American Subaru Impreza Owners Club Tuesday September 2, 2014
Old 05-31-2001, 11:05 PM   #1
Andrew
Member#: 1170
2005 STi
Post Cobb wide throttle body for a ~10psi turboed 2.5RS
I'm wondering if a wider throttle body (namely the cobb one) would do anything for me. I'm looking to push close to 10psi, right now im only at 5-6 (would it help at that amount of psi?) ...or are the gains minimal? i did a search and couldnt find anything that was conclusive...
also this wouldnt be a problem with an IC right? everything would still fit fine correct?
Andrew is offline   Reply With Quote
Old 06-01-2001, 05:44 AM   #2
Joe Hogan
Member#: 699
2002 golf TDI
Post
Andrew,
The enlarged TB from Cobb eases the restriction to flow of air into the engine. The RS I drive has one and I'm running a Vishnu turbo @ 10 psi. The engine is estimated to make 300 - 325 hp. Dyno'd at approx 245 hp to the wheels.
FWIW
JH
Joe Hogan is offline   Reply With Quote
Old 06-01-2001, 07:57 AM   #3
dirk.gecko
Member#: 3141
2007 Scion tC
Blue or something
Post
Actually, there would be an increase in power without running any more boost because overall flow would be up. In theory, at least, dunno how much. To see any real gains, you'd need to do the heads as well ( Cobb notes that the heads are a restriction long before the TB is).
dirk
dirk.gecko is offline   Reply With Quote
Old 06-01-2001, 09:37 AM   #4
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
Post
Heres a question to add...
What about those of us who have a MY99/turbo with the first stock airbox??
As seen here:
<IMG SRC="http://216.242.153.40/MembersList/UserPics/1929/intercooler.jpg" border=0>
Isnt the size of the hole between the airbox and R fender ony like 2" in diameter?
So I would think a bigger TB wouldnt help much at all do to the restriction of airflow at the box. I may be wrong though. Any thoughts?
Rich L is offline   Reply With Quote
Old 06-01-2001, 01:50 PM   #5
Andrew
Member#: 1170
2005 STi
Post
is the throttle body something that you can install in a couple minutes (sorry if that sounds dumb, i have no experience with TBs)? I dont have the money to have someone install the heads, and theres no way that I personally would open up the engine..
Old 06-01-2001, 02:09 PM   #6
efoo
Member#: 80
Post
not really, unfortunately - engine coolant is routed through the throttle body to warm it up and keep the throttle plate from sticking in really cold weather, so to get the throttle body off and on you'd have to deal with coolant. if I get around to doing this to my own car eventually (probably next summer) I will probably time it in conjunction with a coolant flush.
Rich L: I do think you'd probably want a better-flowing air intake before a wider throttle body. However, a wider throttle body may well make a bigger difference on a heavily boosted car, because you have to remember that the air in the throttle body is pressurized. So any little improvement in flow there is multiplied by the amount of boost. If the throttle body is too small then it is essentially a boost obstruction just like the intercooler is (which is why small pressure drops across well-designed intercoolers are crucial) and will cause you to build boost slower in the intake manifold, and therefore the engine.
But, this is probably of no concern to you or me at only 6-7psi. A better intake address the much bigger issue of getting air into the turbo in the first place, which is much further upstream. Why are you still using the stock airbox anyway?
-Edwin
[This message has been edited by efoo (edited June 01, 2001).]
efoo is offline   Reply With Quote
Old 06-01-2001, 02:21 PM   #7
kaos200
Member#: 2692
Post
changing out the TB isn't that hard, it took about 30-60 minutes because of the intercooler. the coolant only spilled slightly and we had rags and something to cap the line handy...
kaos200 is offline   Reply With Quote
Old 06-01-2001, 02:21 PM   #8
t.rod
Member#: 1447
2000 Impreza
2001 Dodge 2500
Post
Has anyone had here TB bored. I think on a NA RS it's subpost to deliver Something like 5HP. I imagine on a Turbo'ed RS it would produce more.
t.rod is offline   Reply With Quote
Old 06-01-2001, 02:54 PM   #9
tomrichardson
Member#: 2672
1973 Porsche 914
Porsche Red
Post
Andrew,
I don't think Cobb carries a larger throttle body for your 2000 Yellow Lamborghini. However, with Cobb being a machinist, he could probably custom fabricate something for you since you've got so much money.
Later,
Tom
[This message has been edited by tomrichardson (edited June 01, 2001).]
tomrichardson is offline   Reply With Quote
Old 06-01-2001, 04:15 PM   #10
Rich L
Member#: 961
Post
Edwin,
Since I dont have a TECII, I still have a MAF issue to contend with. So my options for intake design were limited. My current set up seemed to be the "safest" intake while retaining the stock maf sensor. There is one advantage to this setup, it one of the few CAI for the MY99.
I also agree that under low boost, and stock heads... the TB is probably not going to make a big difference.
Just let me know if your going to sell that TECII for cheap! Ill buy it!
Old 06-02-2001, 11:37 PM   #11
ImprezaRS dot com
over boosted again
Member#: 1458
2013 B9 Tribeca LTD
2005 Impreza 2.5 RS
Post
That hole in the inner fender is over 3" in diameter, almost 3.5". I know that for a fact, from making CAI's for the Impreza/Legacy/Forester.
Larry
ImprezaRS dot com is offline   Reply With Quote
CFM 67mm Throttle Body for 2.3l duratec Focus lytlec Non-Subaru Stuff 0 05-15-2009 05:47 PM
FS: Grimmspeed Ported / Coated Throttle body for 2.0 dcpatters Engine/Power/Exhaust 6 10-13-2008 08:47 PM
manual throttle body for DBW STi for aircraft bmeyette Factory 2.5L Turbo Powertrain 2 04-29-2008 11:30 AM
FS: Cobb Intake System for '00-'02 Impreza 2.5RS Stime187 Engine/Power/Exhaust 17 02-14-2007 03:21 PM
COBB TUNING throttle body SCRAPPYDO Technical Forum Archive 31 10-04-2000 12:31 AM
