Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 08-14-2003, 03:38 PM   #1
essogas
Member#: 35703
2004 WRX STi
Blue/British Black 18's
Default Who changed their Sti Stock exhaust already?
I would like to hear from people who have already taken this step, not from those who are thinking, exploring or speculating what route to take. If you have made the change, what type/brand did you choose and what advantages and disadvantages has your exhaust modification had on the general performance of the car?
essogas is offline
Old 08-14-2003, 04:22 PM   #2
ShagnRS
Member#: 373
2012 Abarth 500
Default HKS Carbon-Ti Catback
Replaced the stock exhaust with the HKS Carbon-Ti catback. Pretty much a direct bolt up except you have to shim the hell out of the spring bolts (Don't re-use the springs). Take up the extra slack created by the spring removal with a spacer over the bolt, or just washer it up.
Better breathing (Not a whole lot, it's only a catback) up top. A little loss down low...so just don't get caught down low (< 2000 rpm).
Love the sound. Low gutteral burble, nice at WOT as well. No droning observed.
One thing you may want to consider though. The Carbon-Ti is the same as the Hi-Power from HKS. The Hi-Power is cheaper. You could use the extra dough to by a down-pipe and run more HP than those of us with the Carbon-Ti Catback system
ShagnRS is offline
Old 08-14-2003, 05:06 PM   #3
awilson529
RIP
Member#: 38867
11 Mazda
I dont have it on yet... but I got a TXS turbo back.
awilson529 is offline
Old 08-14-2003, 05:30 PM   #4
horshack
Member#: 19236
Axis GT35/40R STi
Not back yet
I have a BPM TBE, the TwisterIII.
HUGE difference!
BTW - Don't forget to make the ECU relearn with the new exhaust!
I will have Dyno results on 8/31.
The BUTT Dyno says BIG gains!
horshack is offline
Old 08-14-2003, 06:19 PM   #5
happasaiyan
Member#: 37731
hmm...i never reset my ECU after i did my exhaust...which was probably 700 miles ago. do you think it has relearned by now? or should i just go out and do a reset now. i didnt want to lose my stereo settings, so i just left it alone. is there power or tuning to be had if i do reset? thanks in advance.
happasaiyan is offline
Old 08-14-2003, 06:23 PM   #6
horshack
Member#: 19236
Axis GT35/40R STi
Not back yet
Depends if the ECU had already completed the learn function prior to your exhaust install. How many miles on the car when you completed the exhaust upgrade?
If its a cat-back, I would just leave it alone.
If its a TBE and your car already learned prior to install, then I think you will be more than happy re-programming those radio stations!
horshack is offline
Old 08-14-2003, 06:27 PM   #7
happasaiyan
Member#: 37731
i had about 2500 miles on it when i did the TBE. doesnt the ecu constantly relearn? so in theory it wouldve learned now what it should learn by resetting it?
Old 08-14-2003, 06:28 PM   #8
happasaiyan
Member#: 37731
either way though...i have to go pick up my mbc today after i get home. ill adjust the mbc to 16psi (its already boosting more than that, so lets cross our fingers and see if it will at least somewhat limit my boost creep problem), and then reset it after that. we shall see!
the problem isnt so much the radio stations....but its more the audio settings (bass, treble, mids, etc). stupid complicated stereos. haha.
Old 08-14-2003, 06:31 PM   #9
horshack
Member#: 19236
Axis GT35/40R STi
Not back yet
How many radio stations do you have???????????
I would bite the station programing bullet and reset that ECU.
Make sure you search on the proper way to reset also!
horshack is offline
Old 08-14-2003, 06:48 PM   #10
SGOSWRX
Member#: 10921
04 04 STi
12.8 @ 105 mph
I have Godspeed downpipe and an Greddy EVO catback. That makes my exhaust catless. I can definately feel a good seat in the pants increase in power. I'm waiting to get a boost gauge installed so I can put my high performance boost controller on the car.
SGOSWRX is offline
Old 08-14-2003, 07:12 PM   #11
awilson529
RIP
Member#: 38867
11 Mazda
Just did a search on how to reset the ECU and found no usefull results. SO... how do you do it?
Thanks in advance,
Adam
Old 08-14-2003, 07:47 PM   #12
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Disconnect the battery, step on the brake pedal 1/2 a dozen times during a period of 30 seconds to drain all the power then reconnect the battery. Done
Wombat North is offline
Old 08-14-2003, 08:02 PM   #13
horshack
Member#: 19236
Axis GT35/40R STi
Not back yet
Or Disconnect the battery for 30 min.
horshack is offline
Old 08-14-2003, 08:59 PM   #14
awilson529
RIP
Member#: 38867
11 Mazda
thanks guys
Old 08-14-2003, 10:36 PM   #15
peczenij
Member#: 16791
2004 WRX STi
WRBlue
Put on my TurboXS cat back from my 2002 WRX.
It was like removing a cork. Lots more power.
I cannot believe it...
peczenij is offline
Old 08-15-2003, 12:11 AM   #16
bert_WRX
Member#: 27143
what he said...
bert_WRX is offline
Old 08-15-2003, 01:52 AM   #17
euroauto
Member#: 249
05 FXT psm
12 R350
Changed out at 17 miles, Invida turboback and K&N short ram. WOW! Might be a bit loud so I'm putting the stock muffler back on with a custom made flange. jim
euroauto is offline
Old 08-15-2003, 03:32 AM   #18
wpcalvin7
Member#: 41148
2004 Subaru WRX STi
I just ordered the B&B triflow exhaust, I will keep you guys posted when I install the exhaust, should sound pretty awesome.
wpcalvin7 is offline
Old 08-15-2003, 09:33 AM   #19
Hummer
Member#: 31892
2004 STi
You are correct sir!
Hummer is offline
Old 08-15-2003, 09:51 AM   #20
lstepnio
Member#: 10972
2004 STi (fuxor3d!!)
2004 Forester X
I keep seeing people commenting on with boost spiking/creaping after the exhaust installs. I'm curious to see some more people with gauges to comment regarding this issue.
lstepnio is offline
Old 08-15-2003, 10:43 AM   #21
happasaiyan
Member#: 37731
will be attempting to resolve this issue later tonight when installing my TXS HPBC. im thinking i may have to cap boost to 15psi. i dunno. well see though.
...but yes, it is a problem at ~140 in 6th. BAM boost cut + CEL. peaks out at 1.3bar.
Old 08-15-2003, 11:01 AM   #22
lstepnio
Member#: 10972
2004 Forester X
I assume you're going to be taking the FBC out of the equation w/ the MBC?
lstepnio is offline
Old 08-15-2003, 11:20 AM   #23
happasaiyan
Member#: 37731
im going to be trying a few things...
Old 08-15-2003, 02:50 PM   #24
zacek
Member#: 19467
04 WRX STi
WR Blue - original owner
APS Turbo back here along with APS 65 mil. intake.
Tremendous overall improvement. Boost increased to 15.5psi, I have EGT, A/F and BOOST gauges. I forgot to reset ECu and car backfired (or afterfired) constantly for a couple of days after installation but eventually went away. The gauges now register normal activity after 2 days. I am estimating @ least 20 hp increase on ButtDyno!
It has been about a month now and no CE lights from Exhaust nor from intake. No droning, a little loud @ WOT since this turbo-back was actually designed for the 2 litre WRX, never got this loud on the WRX.
zacek is offline
Old 08-15-2003, 02:57 PM   #25
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
Full Invidia system here...
dsmperformance is offline
So who changes their oil every 7500 miles or 7.5 months? bomber991 Service & Maintenance 23 10-02-2006 08:09 PM
Who put their summers back on already? hahahaha WRC_Obsessed New England Impreza Club Forum -- NESIC 41 03-26-2005 06:41 PM
Who change their front bumper? RCMM Tri-State Area Forum 0 07-21-2001 09:31 AM
Warning to those who change their own oil. Pls. Read. Snoopy General Forum Archive 37 01-24-2001 10:37 AM
For those who changed their steering wheels.... Ver.III Technical Forum Archive 4 08-16-2000 03:54 AM
