Old 08-14-2003, 05:25 PM   #1
mike270
Member#: 12863
2002 2.5RS
Default Compression at shutdown
When you turn your car off I would assume one of the cylinders would stop near maximum compression. If you leave your car alone for a while wouldn't that pressure cause a lot of wear to the rings or the piston? Or is the seal not tight enough to hold that pressure for more than a split second. Or maybe one of the valves opens to release this pressure as part of shutdown?
I hope this makes sense. Just a weird thought
mike270 is offline   Reply With Quote
Old 08-14-2003, 07:53 PM   #2
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
yeah, I don't think the rings make an airtight seal. It might hold the pressure for several seconds, but not much more.
-IggDawg
IggDawg is offline   Reply With Quote
Old 08-14-2003, 11:47 PM   #3
mike270
Member#: 12863
2002 2.5RS
Yeah I kindof figured the seal wasn't air tight for more than it needed to be for ignition. If it were there would be a lot of problems with the rings if it didn't release that pressure somehow.
Also how many kpa or psi roughly is compression on the RS. I don't even know where to begin with a ballpark.
Old 08-15-2003, 03:18 AM   #4
IggDawg
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
depending on which bottom end you have (stage I is '98 and some '99, Stage II is 99.5+ IIRC), the CR is either 9.8:1 or 10:1. for example, a stage 2 bottom end has 10:1 compression ratio. atmospheric pressure is 16 PSi, so it will compress that 10x. ideally, when the combustion chamber is fully compressed, you'd have an absolute pressure of 160 PSi. when doing a compression test, this would only show up as 144 PSi since your gauge would have 16 PSi pushing on it because of the atmosphere. that's called "gauge pressure." whenever you see a boost gauge, vacuum gauge, or any gauge that measures pressure the readings are always in "gauge pressure" unless it's sealed and specifies "absolute pressure."
I think all those numbers are right. someone step in and correct me if I'm wrong.
-IggDawg
Old 08-15-2003, 01:46 PM   #5
mike270
Member#: 12863
2002 2.5RS
That makes sense.
Thanks a lot for the responses. I think its pretty impressive that a car can last for 200,000 miles when the engine is building up 150 psi 2000-3000 times every minute
Unix port of Windows shutdown command (to shutdown wintel hosts FROM unix)? Akirasoft Off-Topic 23 12-04-2006 03:04 PM
Compression test, pull all plugs at once? Impr3zy0u Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-08-2006 02:45 PM
compression tested the Rex today...85k miles, mostly at Stg 4...good results: annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-11-2004 01:41 PM
Does vac at idle dictate compression?? eightballrj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-06-2004 04:49 AM
EJ25 Compression Test Results at 50,000 miles latinskllz Normally Aspirated Powertrain 4 11-11-2002 03:46 PM
