Old 08-14-2003, 04:31 PM   #1
LA
Member#: 7119
2000 impreza rs
blue ridge pearl
Default cobb cams?
i am looking at buying a used car with the cobb mild cams, any problems i should look for when test driving this car, due to the cams?
LA is offline   Reply With Quote
Old 08-14-2003, 07:28 PM   #2
svxr8dr
Member#: 1702
2001 2.5 RS-T
Blueridge Pearl
If you ever want to go FI I've heard that anything above the mild/street cams will be a problem.
svxr8dr is offline   Reply With Quote
Old 08-14-2003, 11:20 PM   #3
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I'd make sure the valve lash adjustments had been made.
AO
m750 is offline   Reply With Quote
Old 08-15-2003, 12:02 AM   #4
LA
Member#: 7119
2000 impreza rs
blue ridge pearl
what does this adjustment pretain to
Old 08-15-2003, 05:09 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
both the mild and the spicy cams can be run with a turbo. They don't have enough overlap to be an issue. But if they are the racer cam, they are strictly for NA use only.
Valve lash adjustment has to do with making sure the shims are set properly to push valves down the right amount and not slap. Ask the guy and if he get a "huh?" look on his face it wasn't done!!!
Old 08-16-2003, 01:35 AM   #6
LA
Member#: 7119
2000 impreza rs
blue ridge pearl
ok thanks for the help
Old 08-16-2003, 02:48 AM   #7
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
The Cobb cams, from what I have heard, will not pass emissions in the stricter states. They may pass federal though.
For Turbo use, the Mild/Street cams are better than Spicy b/c of less overlap.
BAN SUVS is offline   Reply With Quote
Old 08-20-2003, 01:50 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
BAN SUV,
I used to think the same thing, but this is straight from the horses mouth... You can see my posts down the page and then Josh's reply...
http://www.wrxforum.com/cgi-bin/ulti...4;t=000583;p=2
Old 08-20-2003, 06:06 PM   #9
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Originally posted by Matt Monson
BAN SUV,
Thanks Matt. Josh pretty much says that the Mild cams are better for FI on stock internals. If you went really wild with a fully built engine and made tons and tons of power, then the Spicy cams would probably be better.
TWE cams VS. COBB Cams smain38ehampton Normally Aspirated Powertrain 12 02-10-2005 05:19 PM
Cobb Cams installed by Cobb RigdenZW Texas Impreza Club Forum -- TXIC 3 05-17-2002 08:01 PM
Cobb Cams Acceleration Numbers stimpy Normally Aspirated Powertrain 32 04-24-2002 11:36 AM
Questions for people with cobb cam... slamck Normally Aspirated Powertrain 20 04-15-2001 01:33 AM
Cobb Cams or Borla Headers dyswtric27 Normally Aspirated Powertrain 3 03-29-2001 10:46 AM
