Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Old 08-14-2003, 06:45 PM   #1
Aaron Hoag
Member#: 34926
2002 wrx wagon
black
Angry Cel!!! P0133? Front O2 sensor...
Dammit, first Cel in any car I have ever owned
Oh, well,
anyone out there have experience with P0133? Through reading the cel list here at nasioc, it appears to be the front o2 sensor, but would like to check all connections around front sensor before buying new parts or taking to subaru.
any ideas, experience or comments?
thanks
a-
Aaron Hoag is offline   Reply With Quote
Old 08-14-2003, 07:53 PM   #2
rick-l
Member#: 33868
2003 wrx
srp
P0133 - HO2S Sensor Circuit Slow Response
The HEGO Monitor checks the HO2S Sensor frequency and amplitude. If during testing the frequency and amplitude were to fall below a calibrated limit, the test will fail.
Causes
Contaminated HO2S sensor.
Exhaust leaks.
Shorted /open wiring.
Improper fueling.
MAF sensor.
Deteriorating HO2S sensor.
Inlet air leaks.
Access HO2S test results from the Generic OBD-II menu to verify DTC
rick-l is offline   Reply With Quote
Old 08-14-2003, 11:33 PM   #3
Aaron Hoag
Member#: 34926
2002 wrx wagon
black
Thanks for the input, only one question
what is DTC?
thanks
a-
Old 08-15-2003, 12:00 AM   #4
rick-l
Member#: 33868
2003 wrx
srp
Originally posted by Aaron Hoag
what is DTC?
Diagnostic Trouble Code.
If you have more than the basic scanner you can see the values of the failed test and see if it was a gross failure or just a little out.
Front O2 sensor vs Rear O2 sensor (MY00 RS) Jewbaru Service & Maintenance 3 07-29-2012 10:14 PM
WTB: Knock sensor and Front O2 sensor Faster_Gun Private 'Wanted' Classifieds 12 01-30-2010 07:39 AM
P0133 Front O2 Sensor Slow Response familytruckster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-09-2005 02:27 AM
is the FRONT O2 sensor a wideband sensor ? Extraze Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 07-01-2004 04:21 PM
Front O2 sensor and/or EGT sensor (02 WRX) crazyhorse Private 'Wanted' Classifieds 1 11-03-2003 08:35 PM
