Old 08-14-2003, 08:28 PM   #1
AWD Turbo 2004
Visiting NASIOC Timeout
Member#: 41360
2004 WRX impreza
blue
Default help I rounded off a screw
i got a turbo XS turbo controller. the screw in the center that is supost to controll the boost can some one help me to get it out.
AWD Turbo 2004 is offline   Reply With Quote
Old 08-16-2003, 12:31 AM   #2
cwingo
Member#: 33846
I think your SCREWED
sorry man, good luck fixing it
cwingo is offline   Reply With Quote
Old 08-17-2003, 06:49 PM   #3
Full_Clip
Member#: 22218
If the screw is something on like a permanent, non-removable screw (like a thumb screw), then you sir, are screwed. However, if it is not, take a small drill pit (like 3/16) and screw directly into the screw head. This will usually either
1. Drill directly into the screw.
Then, just take the bit out of the drill chuck and use some plyers or whatnot to turn the bit in counterclockwise to back it out.
2. Break the screw head off.
If this happens, just take a small nail and start tapping the screw counterclockwise. It should back out easily. Once teh head has broken off, there is usually little tension holding it in.
Craftsman has a whole toolkit for rounded off/broken screws.
http://www.sears.com/sr/product/summ...id=00952154000
Full_Clip thinks everything is $19.95.
Full_Clip is offline   Reply With Quote
Old 08-18-2003, 04:27 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Screw extractors have worked for me in the past. They are a left hand threaded bit that bites into the screw while attempting to unscrew it. They can be had for a couple bucks down at a hardware store. If the head of the screw is not countersunk, I have also found that a good set of vicegrip pliars will bite onto the screw and allow you to extract it without a screw driver.
-Jon
APS Blow Off Adjustment Screw Size? quickgtp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-13-2009 03:32 PM
Need suspension help fast....rounded bolt 2004_STI Brakes, Steering & Suspension 2 07-23-2008 12:00 AM
Rounded off nut advice dru_hill Service & Maintenance 27 08-21-2006 08:42 PM
Rounded off hex nuts on StopTech calipers, what should I do? garface Brakes, Steering & Suspension 5 05-10-2003 12:25 PM
Rounded off bolt on strut... what to do? Chocobo Brakes, Steering & Suspension 6 01-28-2002 09:33 PM
